November 20, 2025, 05:52:10 PM *
Author Topic: Please Help, thermostat housing o-rings  (Read 1694 times)
Grumpy
Tampa, Fl
« on: January 25, 2010, 08:35:55 AM »
Had a o-ring leaking on the back of the thermostat housing,  got the new o-rings today, and noticed they are tapered with a lip. My question, which end goes in first, the small part or large end of the o-ring. I cannot see any thing in the manual that says any thing about it.
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: January 25, 2010, 08:46:42 AM »
Not trying to be a smart azz, but can't you look at how the old ones were installed?
I did the same job, a few summers back, and if memory serves, I believe the smaller taper goes in to the thermostat housing first...  Making the alignment easier, and popping in to the seat.
Black Dog
Don't you know...
Grumpy
Tampa, Fl
« Reply #2 on: January 25, 2010, 09:28:10 AM »
They were replaced by a friend a couple of years ago, and started leaking again, that is why I was trying to find the correct direction. Don't want to do this yearly.  uglystupid2
Steve K (IA)
Cedar Rapids, Iowa
« Reply #3 on: January 25, 2010, 09:43:23 AM »
This sounds like one of those "Oh Crap!" moments.
Like when I replaced my fork seals.  Grumpy, I'm pretty sure you are a machinist, I was for many years.  That oil seal for the forks has a chamfer on one edge, you'd think that would be the edge that you would drive into the tube, right?  Wrong!  You drive the blunt end in.  I found that out the hard way. uglystupid2  Hopefully someone here has the answer your looking for.  Or try asking the mechanics at the Honda shop.  I know that would be a long shot as most mechanics don't know much about the Valk.  But then again, it is the GW engine and a GW mechanic might know the way that o-ring goes in.  Or try posting that question on a GW board.
States I Have Ridden In
alph
Eau Claire, WI.
« Reply #4 on: January 25, 2010, 10:54:34 AM »
I don’t understand.  I changed my thermostat last year and it had a rubber sealing gasket that fit around the thermostat.  It didn’t have a tapered side, both were the same on either side.  If it really bothers you, get some “form-a-gasket” and do it right.
Grumpy
Tampa, Fl
« Reply #5 on: January 25, 2010, 07:46:34 PM »
This is the back of the thermostat housing, where the two feed pipes go to each head.
