March 21, 2026, 09:27:54 PM *
Author Topic: Ford Recalls 643,000 Escape and Bronco Sports  (Read 1160 times)
« on: November 27, 2022, 06:56:07 AM »
https://www.thedrive.com/news/ford-recalls-643000-escape-and-bronco-sports-over-engine-fires
« Reply #1 on: November 27, 2022, 07:01:19 AM »
I haven't looked at it closely. Apparently there is an intake or fuel delivery issue due to a crack which then leaks fuel with the possibility of a fire.
Jersey mike
Brick,NJ
« Reply #2 on: November 27, 2022, 08:12:25 AM »
Doesn’t sound too encouraging;
“The current fix for the issue as reported by Ford is a drain tube from the cylinder head, directing fuel away from hot surfaces in the engine and preventing pooling. Ford also intends to issue a software update that alerts the driver if fuel pressure is reduced, and puts the car into limp mode.”
“Owners are not instructed to stop driving their cars under the recall, and Ford projects a low failure rate for the injectors. Until a fix is released, owners are urged to stay alert for a fuel smell around the engine bay and should go to a dealer immediately.”
« Reply #3 on: November 27, 2022, 11:27:50 AM »
What struck med was the Bronco has a mighty 1.5 liter engine.  Shocked
1.5 liter in a Bronco. And that's it. 1.5  Cheesy
Same as a Valkyrie.
« Reply #4 on: November 27, 2022, 03:37:07 PM »
I just got a (several years old) Dodge recall done on my 2500 Promaster.
It seems there is some remote possibility of a fire from a fan motor.  I asked the service mgr if I should get it or not, and he said yes.
« Reply #5 on: November 27, 2022, 04:30:39 PM »
They are also recalling for brake issues on some models.
TTG53#1717
Far West Texas
« Reply #6 on: November 27, 2022, 09:48:22 PM »
Who needs brakes ?
‘97 Standard Purple/White
‘13 XL Seventy Two
‘54 KHK
VRCC 1717
Jersey mike
Brick,NJ
« Reply #7 on: November 28, 2022, 03:06:58 AM »
Same as a Valkyrie.
Here’s a couple at local dealer but with 2.7L engines.
https://www.allamericanfordinpointpleasant.com/new-Point+Pleasant-2022-Ford-Bronco-Big+Bend-1FMDE5AH8NLB71035
https://www.allamericanfordinpointpleasant.com/new-Point+Pleasant-2022-Ford-Bronco-CUSTOM+Throwback+Edition-1FMEE5BP1NLB45449
« Reply #8 on: November 28, 2022, 05:08:52 AM »
Talk about pop up ad he'll.
Eeeeeek
« Reply #9 on: November 28, 2022, 05:14:05 AM »
Same as a Valkyrie.
almost all vehicles now are going turbo or twin turbo small displacement engines.  It sucks for sure since long term reliability will be rare.
Even my 2021 new tundra got a recall for replacing the power steering system (could leak power steering fluid) which did not want to do.  Dealer spent 6 hours doing it, me being reluctant for them to do.  They supposedly fixed that issue but caused 2 other problems in the process.   Taking off the front wheel,  they cracked my black plastic hub cap cover (which they have on order) as well as having to do a front end alignment messing up the alignment now having to go back in yet again to get both fixed.  My steering wheel use to be straight and go straight down the road, but now is 15 degrees off since if hold the wheel straight on a straight road,  the truck wanders about 15 degrees to the right very obviously is wrong.
Fing pisses me off go in for 1 recall, dealer causes 2 other minor issues.
Beardo
Regina, Saskatchewan Canada
« Reply #10 on: November 28, 2022, 02:30:10 PM »
Same as a Valkyrie.
That’s the Bronco Sport(based on the Escape). Not the full sized Bronco.
« Reply #11 on: November 28, 2022, 02:49:48 PM »
Same as a Valkyrie.
And they have double the torque of the Valkyrie. It’s amazing how much power they can pull out of engines these days.
