November 11, 2025, 04:52:50 PM *
Author Topic: starts fine, goes to schitt when warm  (Read 2928 times)
baird4444
« on: January 13, 2023, 09:51:13 AM »
HELP....
my 98 goes to hell, runs rough and spits white smoke as if rich once warm. We have cleaned and reset carbs, new plug wires, rechecked all vac lines, carbs are synced,new coils, new iridium plugs, new fuel tap.... compression good.....
mechanic says almost all cylinders go to a misfire....
pickup coil failing when warmed up? this is about the last thing not changed....
mechanic is ready to give up, any help from the VALKYRIE gods?
            tia for any help= Mike
    - ya gotta be SOBER!
     -Cody Baird
clanky
« Reply #1 on: January 13, 2023, 11:45:03 AM »
The one symptom that you brought up that caught my eye was "white smoke".  Any time I've ever seen white smoke coming out of an exhaust points me to steam as in a possible coolant leakage into the cylinder(s) which is one only notices once an exhaust is warm enough to quickly boil water.   Have you checked your coolant lately and or your oil for milky appearance?
Bagger John - #3785
« Reply #2 on: January 13, 2023, 12:10:47 PM »
I'd run a compression test on a warm motor. The side that's lower than the other (aggregated) likely has a faulty head gasket. Replace both if you have the motor apart. Ditto the intake runner seals.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #3 on: January 13, 2023, 05:24:53 PM »
White 'smoke' would be oil. White 'vapor' which dissipates rather quickly would be coolant. Which is it?
« Reply #4 on: January 13, 2023, 06:10:12 PM »
Oil is a blue smoke.  If it is coolant, you should be able to smell it, and the smoke will be white.
baird4444
« Reply #5 on: January 15, 2023, 07:36:02 PM »
Thank you all.....
   oil is not foamy but will check coolant and rest.
         any other options is this the smoking gun?
                 - Mike
     -Cody Baird
rug_burn
Brea, CA
« Reply #6 on: January 16, 2023, 04:05:09 AM »
Another way to tell is how that smoke smells-   Coolant has a sweet smell, it's easy to recognize.  Oil smoke smells well, kind of oily, unsurprisingy.
...insert hip saying here..
ckahler
Glen Allen, VA
« Reply #7 on: January 16, 2023, 08:30:31 AM »
Is the problem all cylinders or just one or two?
Pull the plug wires off plugs 1 & 2. Conect the wires to spare plugs grounded to the engine. Go for a short ride on 4 cylinders. Repeat with cylinders 3 & 4, and than 5 & 6. Any difference in the 3 test rides. If the problem gets down to a pair of cylinders, do the same to just one plug and test ride on 5 cylinders.
Also, if the white smoke is steam, one spark plug should be steam cleaned. perfectly claen.
98 Valkyrie
85 V65 Magna
85 VT500c Shadow
81 KZ305
SCain
Rio Rancho, NM
« Reply #8 on: January 17, 2023, 05:12:33 AM »
HELP....
Years ago I had a similar problem, I had gone through everything as you have and once it was warm it ran like crap, if it was cold it ran great. I had some bad fuel that was causing my problem. You don't mention anything about getting rid of the old gas.
Just my experience, hope you find the problem.
Steve
baird4444
« Reply #9 on: January 17, 2023, 02:39:36 PM »
ok, my mechanic DID do a leak down test on all cylinders as well as oil is clear and coolant is too.
      - damn, thought we had it......
he says his gut feeling is the pickup sensors, really about all that is left....
obsolete except for Ebay so here we go....
                - Mike
     -Cody Baird
Valker
Wahoo!!!!
Texas Panhandle
« Reply #10 on: January 17, 2023, 03:05:08 PM »
A shot in the dark here, but is your clutch misbehaving in any way?
Jims99
Ormond Beach Fl.
« Reply #11 on: January 18, 2023, 04:15:31 AM »
Another odd question, ecu? I know the timing is changed as it warms up. Maybe it’s not working right when warm. Just a thought.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
trout dude
Hammond Louisiana
« Reply #12 on: January 18, 2023, 04:38:06 AM »
You might want o check your vacuum slides and see if any are stuck or have holes in them   Just a thought
Dennis
baird4444
« Reply #13 on: January 19, 2023, 08:40:21 AM »
Clutch is good, I have read that a lot who change ECU wind up changing pickups for the fix....
the pickup on eBay is gone and having a hard time finding one, anybody got a spare they'd sell?
                 - Mike
     -Cody Baird
ckahler
Glen Allen, VA
« Reply #14 on: January 19, 2023, 05:55:01 PM »
Although the P/N's are slightly different, pickup for a 1500 Goldwing may work.
98 Valkyrie
85 V65 Magna
85 VT500c Shadow
81 KZ305
burple05
Van Buren, Arkansas
« Reply #15 on: January 20, 2023, 08:39:00 AM »
HELP....
What SCain said.  Had same problem.  Checked fire at plugs, fuel delivery.  Had filled up my bike weekend before after a ride with my buds.  We all did at same station.  Different pumps.  Drained almost full tank, got new fuel problem solved.  I ran all that "bad gas" in my push mower.  It ran fine in the mower.
It's the same, only different.
baird4444
« Reply #16 on: January 22, 2023, 07:34:02 PM »
yes, went this route with the middle 3 letters being different....
         hopeful.....   - Mike
     -Cody Baird
Ramie
2001 I/S St. Michael MN
« Reply #17 on: February 09, 2023, 10:33:04 AM »
You haven't mentioned what your plugs look like.  Just curious.
