February 11, 2026, 09:58:51 PM *
Author Topic: Bat wing discoveries  (Read 2005 times)
Grey wolf oz
« on: February 03, 2023, 09:04:09 PM »
Sooo,,
( never a good start )
Pulled the guts out for the I/S faring to fit some risers,,,,,,
The threaded plugs in the fairing that Receive  the screws for the speaker housing and other goodies have all spun in the sockets
One of the sockets is shattered with epoxy all over it,
Looks like P,O”S adventures were frequent
Anyway
Any tip on setting the threaded sockets in
I was planning on using some two part epoxi to set the sockets back in to the plastic
Thanks in advance
Luke
NewValker
VRCC# 36356
Oxford, MA
« Reply #1 on: February 04, 2023, 01:43:38 AM »
When mine spun out, I used J B Weld, worked fine.
Don’t get it in the threads.
Craig
Turns out not what or where,
Grey wolf oz
« Reply #2 on: February 04, 2023, 02:17:53 AM »
Yes i have some mould release wax ill use that in the thread,
Was figuring on putting it on the screws and placing it in the socket with glue
See how i goi Smiley
« Reply #3 on: February 04, 2023, 07:56:58 AM »
I have used super glue and baking soda in the past with good results.
da prez
Wilmot Wi
« Reply #4 on: February 04, 2023, 09:49:38 AM »
  I always use the black  ABS glue. N O T  the multi purpose. I also buy the small can.  MEK is also a need in repairs. Clean and lube the threads and take your time.
                                              da prez
Grey wolf oz
« Reply #5 on: February 04, 2023, 02:33:05 PM »
MEK is nasty stuff,,
You gotta be in a well ventilated area for it
Bagger John - #3785
« Reply #6 on: February 06, 2023, 08:59:00 AM »
I use JB Weld on these. And put a dab of anti-seize on the screws, lightly seat them in place and wait 24h before backing them out to attach the inner fairing panels.
Once fixed they tend to stay fixed - and don't forget the anti-seize if you have the fairing apart.
« Reply #7 on: February 06, 2023, 11:01:18 AM »
Grey wolf oz
« Reply #8 on: February 06, 2023, 09:35:50 PM »
I found some JB weld plastic epoxy worked well !!
