November 11, 2025, 06:39:26 PM *
Author Topic: Heal toe,,, wont shift :(  (Read 1584 times)
Grey wolf oz
« on: February 06, 2023, 01:13:22 AM »
Hola
So finally had a chance to run the bike after the shifter install
Hmmmmm. Would not down shift
Very reluctant to up shift either
One of the guys here commented about needing some slop,  I figure i had enough,,
I took the red eye shifter steady off
Upshifting was easy now and back down
Natural, 2nd, natural
But that was it
Took the heal toe off and
We back to normal
Advice required
Of course Cheesy
Luke
SCain
Rio Rancho, NM
« Reply #1 on: February 06, 2023, 05:25:37 AM »
Looking at the last picture of your setup in the other thread, I would say you need the H/T shifter bolt in the rear hole of the OEM foot peg bracket.
Your H/T shifter is too far to the rear so the hoop that goes over the shifter doesn't have any slop for shifting.
When the OEM Shifter goes up or down, it also moves forward slightly, so the slop in the hoop is needed.
You could also try drilling a hole 1/2" to 3/4" forward on the same bracket you have now to give it some play.
Hope this makes some sense.
« Last Edit: February 06, 2023, 12:28:54 PM by SCain » Logged
Steve
Savage
United States
« Reply #2 on: February 06, 2023, 09:08:38 AM »
https://drive.google.com/file/d/1XNq1n-wyfxK5aNiKU30Y3q5f3yXIT1zu/view?usp=sharing
Columbia, South Carolina
Grey wolf oz
« Reply #3 on: February 06, 2023, 09:32:11 PM »
Thank you !
Yes understood,
I will try that this weekend !
Photo for reference
[/quote]
« Last Edit: February 06, 2023, 09:47:02 PM by Grey wolf oz » Logged
Grey wolf oz
« Reply #4 on: February 06, 2023, 09:34:09 PM »
Thank you sir !
Grey wolf oz
« Reply #5 on: February 10, 2023, 12:25:18 AM »
Well
Took some mucking about,   But its working
Installed on the original rear peg mount hole
Love it
Grey wolf oz
« Reply #6 on: February 10, 2023, 06:02:10 PM »
Update,
So i used the rear stock riders foot peg mount for the pivot
I’ve packed the pivot point out 20 mm ( just over 3/4 inch )
I will make a packer for that
The shift lever has had a M8 bolt. Fitted to bar on it from PO
I spaced out the new lever toe bar with M8 nuts,  that gives me enough space and slop for the shifter to be happy
So i need to turn a 3/4 round 3/4 long spacer for the shifter arm pivot and a 1/2 round /3/4 long spacer for the toe bar and i am done
I’m not gonna mess with linkages as happy with the shift action now
Case closed
Cheesy
