November 11, 2025, 06:39:32 PM *
Author Topic: Lights not turning on after battery change  (Read 1917 times)
shadowmagic
« on: April 13, 2023, 11:14:03 AM »
So my battery went bad. Put in a new one and now it wont start, lights dont come on or anything. Anything simple I should check? thanks for the help
RonW
Newport Beach
« Reply #1 on: April 13, 2023, 11:33:17 AM »
  • Recheck battery connection..
  • Fuse?
2000 Valkyrie Tourer
« Reply #2 on: April 13, 2023, 02:01:00 PM »
Check the ground wire to the frame.  Make certain it's tight.
Avanti
Stoughton, Wisconsin
« Reply #3 on: April 13, 2023, 06:52:53 PM »
Most ground wires go to the left back side of the transmission. I always put a ground strap from that transmission ground over to the frame. This makes a more positive ground.
May not be your problem but one to fix when checking for grounding problems.
Rio Wil
« Reply #4 on: April 15, 2023, 02:38:15 PM »
Any chance the battery was briefly hooked up backwards..... Cry
Clarkcelt
« Reply #5 on: April 17, 2023, 08:29:26 AM »
Since I had my *cough, cough* issue in the last year, I always suggest checking the wires in the headlight bucket, especially if you had any accessories installed by the PO. In my case, it was a Cobra light bar, and one of the wires was cut, and the bar's lights spliced into it. If you have a loose wire in the bucket, that could do it.
bassman
« Reply #6 on: April 17, 2023, 01:45:03 PM »
Kill Switch accidentally on??
h13man
Indiana NW Central Flatlands
« Reply #7 on: April 18, 2023, 06:40:02 AM »
I always throw a 2 amp. charge on a new battery especially if I had to add acid as that is a requirement. BTW battery tenders are not chargers. Don't ask how I know.  Wink
