January 30, 2026, 08:01:05 AM
cross over parts?
Topic: cross over parts? (Read 2020 times)
deez
Builder of the Locost Seven on Steroids
Lee's Summit Mo.
cross over parts?
January 30, 2010, 07:52:08 PM »
Has anyone used goldwing rear air shocks on their valk? I found one post here where a guy did it but didn't say how his experiment turned out. I tried a pair of harley showas I got off ebay , but the pressures I needed to ride right were WAY over the harley max recommened. I had to run 80 psi! I work on our local police bikes , most run 20-30 psi with a max load , so I suspect the problem is in the angle and position of the mounting causing excessive mechanical advantage on the valks swing arm. comments?
Re: cross over parts?
January 31, 2010, 05:47:53 AM »
Progressive make air shocks for the Valk and the Goldwing usually is a mono shock and would require modification to the swing arm and mounting. I know that the Progressives may be a bit pricey but sometimes its the best way to go. Of course like anything ask yourself do I want to ride or modify my bike
