December 28, 2025, 11:18:19 AM *
Author Topic: Goldwing ECM transplant into 97 Valkyrie??  (Read 2894 times)
Crusty1
« on: May 07, 2023, 07:12:10 PM »
Has anyone tried to transplant an ECM from a 98-00 Goldwing into a Valkyrie to replace the ICM? I am attempting it now. Love the Valkyrie but the fuel consumption is horrid. Comparable Goldwings are getting 35-38 MPG.  Best Ive seen on 97 Valkyrie is 30-31.  Even a few MPG improvement would be better.
Crusty
« Reply #1 on: May 07, 2023, 07:48:06 PM »
Haven’t heard of it. I doubt it would be easy, even if possible. There are other things also impeding our mpg between the GoldWing. Personally I don't consider a 6-7 mpg difference all that horrid.
« Reply #2 on: May 07, 2023, 08:05:29 PM »
... Love the Valkyrie but the fuel consumption is horrid. ...  Best Ive seen on 97 Valkyrie is 30-31.  Even a few MPG improvement would be better.
Without mods you should normally get 35 - 40 mpg.  The ICM is not your issue.
Crusty1
« Reply #3 on: May 07, 2023, 08:36:16 PM »
I maintain 3 of these valkyries for friends.  Rebuilt carbs, changed ICMs, needle jets air filters, etc… I’m open to suggestions.
« Reply #4 on: May 07, 2023, 08:42:48 PM »
What needle jets?  What fuel are you running?
Crusty1
« Reply #5 on: May 07, 2023, 08:46:15 PM »
I ride a  2000 GW SE and a 2007 ST1300.  35-38 on the GW and 45-47 on the ST.  30-31 on a Valkyrie sucks. Why does the best looking bike ever get the worst mileage.
ridingron
Orlando
« Reply #6 on: May 07, 2023, 09:02:48 PM »
I rode with a buddy on his GW1500. Compared to my ST1100 his MPG was terrible!
Remember you're pouring gas into 6 carbs on the Valk.
Have you guys swapped bikes (for a full tank) to see if the MPG stays with the bike or follows the rider?
« Reply #7 on: May 07, 2023, 11:43:13 PM »
I have a ‘97 tourer and consistently get 36 even at 75+ at 3500 RPMs.
Remember the 1500 wing has 2 carbs and different cams.
« Reply #8 on: May 08, 2023, 03:41:17 AM »
Valkyries seem all over the place to me. I don't think in terms of mpg,
but  I go on reserve around 115. Wimp's Red and White will go 150 or more.
It seems like when we'd stop, I'd always get a gallon more than him.
I've heard many different answers for "when do you go on reserve?" over
the years...
Steel cowboy
Spring Hill, Fl.
« Reply #9 on: May 08, 2023, 05:09:24 AM »
On my interstate, 35.7 mpg. This weekend, solo, averaging 70 mph. Some stop and go in traffic.
2001 black interstate
2003 Jupiter Orange wing
Crusty1
« Reply #10 on: May 08, 2023, 09:02:38 AM »
UPDATE:  The GW ECM was successfully transplanted into the 97 Valkyrie.  Seems to run just fine and better low end.  Road testing this week to test mileage.
ridingron
Orlando
« Reply #11 on: May 08, 2023, 08:34:18 PM »
Was it plug and play?
What did the tech do?
I am interested in hearing the results in both riding and MPG.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #12 on: May 09, 2023, 07:38:35 AM »
I would like to see a picture of the ECM. What is the part number? What model Goldwing did it come off of?
So many roads, so little time
VRCC # 5258
Bagger John - #3785
« Reply #13 on: May 09, 2023, 02:11:43 PM »
Definitely interested as well.
« Reply #14 on: May 09, 2023, 08:01:15 PM »
Which model Valk? Std/T or IS? IS would be either a better match to the GW, or worse.
If you want better mileage, get a larger diameter rear tire. I've still to mount my ATT to my IS, but I would expect something like 5% better miles or faster bike.
Crusty1
« Reply #15 on: May 10, 2023, 07:52:09 PM »
Crusty1
« Reply #16 on: May 10, 2023, 08:04:15 PM »
It was not plug and play.  I had to build an adapter harness destroying an old ICM and a GW wiring harness.  I believe the ECM and harness are from 98-00 GW if the Ebay supplier is believable.  I only used the wires needed to match the Valkyre ICM.  I am ignoring the remainder of the GW inputs (IAT, 2nd, 3rd,4th, OD)  for now.  I will be testing the other inputs after my initial baseline tests are complete.  So far it runs fine and has improved low end torque when accelerating away from a stop.  I will report back after a couple of tanks of data are gathered.
I dont understand your question about the TECH.  If you mean TACH It works fine as the GW Tach lead is Yellow/Blue instead of Yellow/Green.
ridingron
Orlando
« Reply #17 on: May 10, 2023, 09:30:34 PM »
I somehow got the idea someone was doing the swap for you. You are the Tech (technician).  Smiley
Crusty1
« Reply #18 on: May 11, 2023, 10:40:00 AM »
I passed the rank of tech back in high school. I’m the mechanic, tech, engineer and motorcyclist.
« Reply #19 on: May 11, 2023, 12:30:05 PM »
GW ICM provides a vacuum advance for more advance during part throttle cruise, this is where the MPG war is won or lost.
https://www.goldwingfacts.com/threads/gl1500-ecm-ignition-timing.320266/
Crusty1
« Reply #20 on: May 11, 2023, 04:08:49 PM »
Quote GW ICM provides a vacuum advance for more advance during part throttle cruise, this is where the MPG war is won or lost.
That is precisely why I picked the GW ECM.
turtle254
Livingston,Texas
« Reply #21 on: May 11, 2023, 07:14:07 PM »
Looks like you have the vacuum line hooked up off the ECM?
Crusty1
« Reply #22 on: May 11, 2023, 08:04:59 PM »
[/quote]Looks like you have the vacuum line hooked up off the ECM?
[/quote]
Trust me it is clearly connected
Flat 6 man
Washington state
« Reply #23 on: May 20, 2023, 05:05:01 PM »
My mileage jumped from 33 to 38 after installing a 6 degree advance wheel.
1998 Valkyrie with Cobra exhaust and optional two-tone paint
Bagger John - #3785
« Reply #24 on: May 21, 2023, 03:55:00 PM »
Using regular or premium?
Mine jumped a good bit by the installation of I/S carb springs, Dynojet needles and an I/S ICM - this on a '99 CA-model Tourer. I've had similar results on other Valkyries.
The CA models have different cam profiles than the 49-staters. Perhaps this aids mileage at the loss of a bit of power but I have zero problems passing anything with that bike when running 2-up - even with a full trunk and saddlebags.
At 75MPH on the highway I easily and consistently see 40-42MPG. It has a Bat Wing and I/S radiator/pods. And it can run on 87 octane gas.
Crusty1
« Reply #25 on: May 28, 2023, 07:58:13 PM »
***update***. The transplant was a measured success.  After running on the GW ECM the Valkyrie went from 30 mpg to 34.5 calculated over 1000 miles. When time allows I will be documenting advance curves on the stock ICM, the GWECM using only basic sensors and testing the effect of the unused sensor inputs.  Will update later.
« Reply #26 on: May 29, 2023, 04:18:43 AM »
u can see the stock std/tourer OEM advance curve here
https://www.manualslib.com/manual/396434/Dynatek-D3k1-1revd.html?page=2#manual
