January 30, 2026, 08:01:21 AM *
Author Topic: Front Fork Springs  (Read 1920 times)
asfltdncr
« on: January 31, 2010, 09:39:11 AM »
Is there any way to identify whether my fork springs are original or Progressive?
Also, if installing new Progressives, is anything other than the springs necessary?
« Reply #1 on: January 31, 2010, 10:08:56 AM »
Not being a smart aleck - if you go down the road and goose the throttle, let off, goose the throttle,
let off, a few times does it feel like you're riding a pogo stick? OEMs...
They do look different next to each other... I wish I remembered exactly... the OEM springs
are tighter wound on one end I think...
You'll want to have several bottles of new fluid.
You can measure the fluid level from the top of the fork tube (springs out):
  Right
    std/tourer: 5.3 inches
    Interstate: 5.4 inches
  Left
    std/tourer: 5.6 inches
    Interstate: 5.8 inches
There's a tool for the right side, I don't know any way around it (or a facsimile)...
You have to overcome the compression of the springs to get to where you can swap out the springs,
it is different on each side...
Check http://www.valkyrienorway.com/ for a PDF of the factory manual, and video of Dag
working on his forks...
« Last Edit: January 31, 2010, 10:26:43 AM by hubcapsc » Logged
