December 28, 2025, 11:18:22 AM
Air Filter O'rings / Gaskets
Topic: Air Filter O'rings / Gaskets (Read 1709 times)
pais
One more turn should do it!
Kent, Ohio
June 05, 2023, 04:04:03 PM »
I ordered and received a new air filter along with a new breather cap for the rear end. I received, didn't order, but was charged for 2 o'rings. I looked them up on the parts fiche. They go inside the bottom and the top of the air filter housing. I did not remove any when I pulled out the old filter. Does anybody use these o'rings? Do you replace them when you replace the air filter? I do not remember ever seeing these.
jim@98valkyrie.com
Wayne, PA
Re: Air Filter O'rings / Gaskets
June 05, 2023, 05:18:09 PM »
If the bike has had a K&N filter, at least one of the o-rings is discarded. Yes, you should use both of the o-rings. Helps to keep dirt out of the airbox.
pais
Kent, Ohio
June 05, 2023, 05:32:03 PM »
Quote from: jim@98valkyrie.com on June 05, 2023, 05:18:09 PM
I am definitely using them. It's gonna be a PIA trying to get them to stay, especially in the top section.
June 05, 2023, 07:41:39 PM »
Quote from: pais on June 05, 2023, 05:32:03 PM
Put a little grease in the channel and it will stay in place.
=> InZane XXV
