December 28, 2025, 11:18:22 AM *
Author Topic: Exhaust end caps stuck  (Read 1768 times)
Knapdog
South Wales, UK
« on: June 06, 2023, 03:19:43 AM »
I've bought a pair of used exhausts, which are actually in very good condition once cleaned up, with a view of cutting the pigtails off.
I didn't want to do that on my originals.
However, I'm having difficulty getting the end cap off. I haven't tried the other one yet.
I've squirted in Penetrating Oil and have applied some heat and started banging the edge with a cold chisel but it's not moving.
Any advice please?
Stay between the hedges!
'98 Honda Valkyrie Tourer⁸
'96 Honda C90
'83 Honda C90C
Knapdog
South Wales, UK
« Reply #1 on: June 06, 2023, 03:41:13 AM »
OK. I've managed it with more heat, more lubrication and a bit more chisel persuasion.
Presumably, you would have done the same.
'96 Honda C90
'83 Honda C90C
h13man
Indiana NW Central Flatlands
« Reply #2 on: June 06, 2023, 05:48:46 AM »
My piggie's were cut and with stock tip's, very annoying at 60mph. cruising. I made a set of open slash cuts that produces a nice roar instead. Use SS bolts and anti seize going back together.
Bagger John - #3785
« Reply #3 on: June 06, 2023, 06:47:38 AM »
My I/S has exactly this setup. Throaty sound at lower speeds but you don't really notice it on the freeway.
wirral_biker
Wirral, ENGLAND
« Reply #4 on: June 06, 2023, 11:31:07 AM »
Bought my first ( new ! ) Honda Valkyrie in 2000.....everyone was banging on then to cut the piggies off...which I did, and hated the rasping noise !!   Professionally  welded back on and the world was a happier place Grin
I will never learn, on my 4th Valkyrie now !
