February 11, 2026, 04:54:55 PM *
Author Topic: Flat,, dead short  (Read 2341 times)
Grey wolf oz
« on: August 06, 2023, 12:42:19 AM »
G’day team
Last week i went to take the valk out
Flat,,,,,,  no juice ,,,,,,  dead battery
How rude !!
Ok so its not done that before ,
I banked it for the weekend
Tried to get her going with a whack pack,
Nothing
Ok how hard can it be
Removed the hot wires from the battery
Fuses
Main 55a fuse ,, gone
15 amp Audio gone
Main 30 gone
Thats odd
Ok so replaced and fired it up
No stereo,, but,,,
Run a good load of miles on it and got a good charge on the battery again
Today
Audio 15 amp gone
Removed the clarion unit
Contact cleaned plugs
Plugged in the green multi pin,
Ok
Plugged in the blue multi pin
Pop
Another 15 amp
So i am assuming i have a dead short in the clarion unit or the blue multi pin
Any on any idea ?
Got a feeling the blue goes up to the dash and aux controls
Luke
Jims99
Ormond Beach Fl.
« Reply #1 on: August 06, 2023, 04:49:51 AM »
Sorry I don’t have a simple answer,  it check the wires running up to fairing. Did the seat or tank pinch a wire somewhere or maybe up by the neck. Is Alternator not exceeding 14.5v. With all those fuses blown at once, I would say something got pinched and released when you pulled seat, move handle bars or a side cover? How’s the connection on the staring relay?  Hopefully someone will chime in with something better. Good luck.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Grey wolf oz
« Reply #2 on: August 06, 2023, 12:28:58 PM »
Starting relay is ok,
Also
Forgot to mention,
Driving light relay had fallen apart, not sure how relevant
Other thing is the audio harness was popping fuses even with the ignition off
Grey wolf oz
« Reply #3 on: August 07, 2023, 03:34:41 AM »
Further,,,,
Part of the radio LCD is active with the ignition off,
Tank off tomorrow for exploritude
Grey wolf oz
« Reply #4 on: August 07, 2023, 05:25:41 PM »
Well
Tank off this morning,  there is nothing visible in the wiring harness,  so maybe the dash,,,,
Open too suggestion ,,,,
Note that with the audio system disconnected no running or charging issues remaining
Has anyone got an OEM audio system / dash for sale ?
I will pull the dash apart on the weekend ,,,, no time left today
H e l p
Grey wolf oz
« Reply #5 on: August 08, 2023, 12:57:45 AM »
Nothing in the wiring harness exploration today
Next weekend ill pull down the dash board and see if there is any thing in there,
There are a few clues in the manual ,  slow work
Just as well it is winter ‍️ Huh? Cheesy
But grateful its a runner as it is !
« Last Edit: August 08, 2023, 01:00:46 AM by Grey wolf oz » Logged
rug_burn
Brea, CA
« Reply #6 on: August 08, 2023, 09:21:16 AM »
     Not sure what the blue and green plugs are:  speakers, power, antenna, etc?   But i'd start by going through with a voltmeter, check the plugs, particularly the outputs to see if they have 8 ohms, etc, or if they're shorted to ground.    Sounds like the power is good, but check it anyway, you might find something.
   Check the unit without the speakers connected for a few seconds.  Does it blow the fuse then?   If you could rig up a speaker-test output from a portable radio etc, you could see if one of the speakers is dead, therefore maybe shorted somewhere.
...insert hip saying here..
Grey wolf oz
« Reply #7 on: August 12, 2023, 06:47:21 AM »
Had every thing off both ends of the stereo system
There is 12 volts coming back down two lines, key off,
Need to pull the tank tomorrow and hunt for a pinned wire
