February 11, 2026, 03:15:17 PM *
Author Topic: Thw whistling noise and intakes in general  (Read 2473 times)
DatBoi69YOLO
« on: August 10, 2023, 04:48:42 AM »
The Valkyrie makes a characteristic whistling noise during idle as it sucks air into the intake. Have any of you tried to reduce that noise, maybe by adding performance improvements like blowers?
Also, is it possible to make v-stacks (or a similarly functioning device) that are actually functional— not just decorative, like these? https://www.prlog.org/11475544-aeromach-velocity-stacks.jpg] [url]https://www.prlog.org/11475544-aeromach-velocity-stacks.jpg[/url]
« Reply #1 on: August 10, 2023, 06:40:39 AM »
The Valkyrie makes a characteristic whistling noise during idle as it sucks air into the intake. ...
Mine don't.  Are you mistaking the sound of the timing belt rotation for a whistle?
DatBoi69YOLO
« Reply #2 on: August 10, 2023, 07:40:28 AM »
Hm. Maybe I am.
No idea how to figure that out, though, except in person. What I’m talking about sounds like air being gently sucked through a Venturi but I guess it might be a belt
Glaserbeam
Southern California
« Reply #3 on: August 16, 2023, 03:17:59 PM »
My 2 cents:  functional velocity stacks would be much louder than an airbox with filter, because they're right out in the open, as opposed to air coming through the air filter and box which is silenced a bit by those components and blocked from your ears by the fuel tank.
I also think the intake noise is sometimes as loud as the exhaust noise, because you have 6 carbs feeding 6 hungry cylinders.  That's a lot of air movement.  But it's normally only when accelerating hard when the noise is intrusive - if the noise is present when decelerating, then it's not intake noise but belt noise or other noise as indicated in other responses.
You can try spraying a sound-deadening coating inside the airbox including the underside of the lid - I'm going to do that the next time I change my air filter.
da prez
Wilmot Wi
« Reply #4 on: August 16, 2023, 07:36:03 PM »
  Try checking the hose clamps above the runners. Just tighten. I usually loosen and then tighten. Do not horse them. Check the intake bolts. Use a torque wrench, Try a sniff of Ether  on a running bike, A light squirt at base of runners will tell you if o-rings are bad. If engine revs a little , you have a bad o-ring.
                                                           da prez
« Last Edit: August 29, 2023, 04:49:33 PM by da prez » Logged
Jims99
Ormond Beach Fl.
« Reply #5 on: August 17, 2023, 04:12:40 AM »
I don’t think I would. If anything were to come loose, that’s all after the filter and can get sucked right into the carbs and engine.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
« Reply #6 on: August 17, 2023, 07:56:05 AM »
I know I wouldn’t. Sounds like a terribly idea to me.
da prez
Wilmot Wi
« Reply #7 on: August 29, 2023, 04:49:05 PM »
 If the runners are leaking , you are already sucking in some dirt. If you do not want to use ether  , WD40 will work. A sniff will not destroy the engine.
                                                 da prez
klb
Hickory nc
« Reply #8 on: August 30, 2023, 10:09:43 AM »
To give you something to compare it to here is a video of my 2001. You can hear the whining sound from the timing belts.
https://youtu.be/wvPciPbJ0rY
