January 30, 2026, 08:01:16 AM *
Author Topic: Interstate Radio Upgrade  (Read 2868 times)
HickoryNCInterstate
« on: February 02, 2010, 03:22:36 PM »
Has anybody upgraded the factory radio on a interstate with an aftermarket amp?
Thanks for the help form the smartest group on the 'net.............Terry
Steve K (IA)
Cedar Rapids, Iowa
« Reply #1 on: February 02, 2010, 09:36:48 PM »
Yes.  Got this from Electrical Connections.  I can roll down the Interstate with the volume set at 6 and hear it just fine over my Mark T exhaust.  I upgraded all 4 speakers to Alpine.
States I Have Ridden In
HickoryNCInterstate
« Reply #2 on: February 03, 2010, 07:19:24 AM »
Thanks Steve  Where did you mount the amp?
Jeff K
« Reply #3 on: February 03, 2010, 07:37:28 AM »
I put one under the fairing too.
asfltdncr
« Reply #4 on: February 03, 2010, 09:43:42 AM »
The amp is your fairing, right?
Jeff K
« Reply #5 on: February 03, 2010, 10:27:04 AM »
Shields me from alien space rays.  Grin
Steve K (IA)
Cedar Rapids, Iowa
« Reply #6 on: February 03, 2010, 09:08:10 PM »
It's in the fairing.  I used a pair of steel 4" L brackets.  Drilled and tapped the triple tree, bolted 2 strips of bakelite to the brackets and then the amp to the bakelite.  You can see the brackets have a slight bend in them.  The amp sets in the area in the fairing that is just above the headlight assembly.  There is about 1/4" clearance top and bottom between amp and fairing.  Looks like it is dangling out there, but it hasn't moved at all in 3 years.  I wasn't sure I could get mine mounted like Jeff K's.  If I remember correctly, the amp measures 7" x 9".  You can see it is set back as far as it will go...it touches the back side of the dash panel.
