February 11, 2026, 03:16:04 PM *
Author Topic: Feel as if something's not right, but not sure.  (Read 2514 times)
Knapdog
South Wales, UK
« on: August 15, 2023, 03:45:06 AM »
 Bike was lacking a bit of power and idle dropped down to 500rpm.
Tiny bit of deposit in the rank which I cleaned.
Air filter only 5000 moles and looking like new.
Took the carbs out and cleaned the jets but they were good anyway. Little bit of sediment in a couple of bowls.
All float needles good and working.
Put all back together. Took for a ride then digitally synced the carbs and they're all spot on.
I seem to have plenty of power. Very good acceleration but sort of feel that the sound is not right.
All hoses and vacuum caps newish and sound.
Plugs iridium and gaps checked.
Sounds as if there's a minute bit of "missing" somewhere.
Any thoughts you can offer and pinpoint to something?
Started to wonder if there actually is a problem or possibly a couple of percent of one.
Sorry to be vague.
Obviously,  initially there was but I've done a lot to try to sort it.
« Last Edit: August 15, 2023, 03:57:49 AM by Knapdog » Logged
Stay between the hedges!
'98 Honda Valkyrie Tourer⁸
'96 Honda C90
'83 Honda C90C
Jims99
Ormond Beach Fl.
« Reply #1 on: August 15, 2023, 04:23:03 AM »
I’ve heard from a few people that the factory plugs are the way to go. Some of the higher performance ones don’t work right in our bikes. Cheap easy to try. I personally never tried anything but stock.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Knapdog
South Wales, UK
« Reply #2 on: August 15, 2023, 06:00:01 AM »
I've still got the previous, which I put in for around 1000 miles. Will try those and see if there's a difference.
There could well be a very slight blockage in just one of the jets somewhere, which is actually what it feels like.
I've put some carb/fuel injector cleaner in the tank this afternoon to see if that helps.
'96 Honda C90
'83 Honda C90C
Bagger John - #3785
« Reply #3 on: August 15, 2023, 09:59:23 AM »
Run a compression and leakdown test on all the cylinders.
Knapdog
South Wales, UK
« Reply #4 on: August 15, 2023, 02:02:58 PM »
I haven't done much since my last post as, since it's my wedding anniversary, I've been on my best behaviour and doting on Mrs Knapdog,  as opposed to the "fat lady", and treated her to a fine meal out at a local Inn ( a lie.... she treated me).
I took the iridium out and replaced with my nearly new NKG standard plugs with .035" gaps.
As soon as I started her up she had a little backfire (never known before) from the left exhaust but seemed to be idling very sweetly ( the fat lady, not Mrs Knapdog) and smooth on the throttle.
I have a new cbr600 petcock instead of Vacuum related oem. I ALWAYS turn it off.
The only other thing I did was tighten some of the exhaust studs up around 1/32 of a turn, if that,  which is hardly anything.
Looking forward to taking her out in the morning.  It's now 10pm here and ready for bed. I'd forgotten it was our Anniversary when I woke up this morning but that's another story.
'96 Honda C90
'83 Honda C90C
Knapdog
South Wales, UK
« Reply #5 on: August 16, 2023, 08:17:43 AM »
Right, it feels sorted.
Standard plugs now in with .035" gap. I've double checked the tightness of air intakes, exhaust studs etc.
All is well, particularly with the Kuryakyn 4050 highway pegs fitted as well for the first time.
'96 Honda C90
'83 Honda C90C
« Reply #6 on: August 16, 2023, 09:28:00 AM »
best to gap plugs are 0.031. the coils are marginal for any thing more.
mod to do is cut back the side electrode so it is half way over the center electrode and round off the end.
Knapdog
South Wales, UK
« Reply #7 on: August 16, 2023, 10:05:23 AM »
Appreciated.  Thank you, but could you elaborate a bit more about cutting back the side electrode  please?
Do you mean the top bendy bit that curls over?
..... and sawing  a bit off so the end us in line with the middle of the centre electrode?
« Last Edit: August 16, 2023, 10:09:06 AM by Knapdog » Logged
'96 Honda C90
'83 Honda C90C
« Reply #8 on: August 16, 2023, 11:48:13 AM »
yes
Knapdog
South Wales, UK
« Reply #9 on: August 23, 2023, 12:03:39 AM »
Furthermore, I discovered I'd pinched two of the air box "legs" where they fit around the back on the intakes.
At last it's breathing properly.
'96 Honda C90
'83 Honda C90C
