February 11, 2026, 04:55:04 PM *
Author Topic: Bank angle sensor???  (Read 2997 times)
Jim500
North Royalton Oh
« on: August 15, 2023, 10:59:51 AM »
I replaced my clutch and all back together. I try to start..... NOTHING tickedoff tickedoff tickedoff and all ideas welcome. Bank angle sensor do this??? and where is it???
« Last Edit: August 15, 2023, 11:02:41 AM by Jim500 » Logged
WintrSol
Florissant, MO
« Reply #1 on: August 15, 2023, 11:16:56 AM »
The sensor should reset when you turn the key off, provided it didn't get tilted. It is behind the panel (center cover) the seat unlock keyhole is mounted to, right of that keyhole.
Before you go looking, make sure you haven't bumped the run/stop switch to the stop position (don't ask).
For clarity, the cable from the 3P connector goes to the sensor, as the text implies.
Also, reconnecting the cable to the latch assembly can be a real bizch.
« Last Edit: August 15, 2023, 11:28:23 AM by WintrSol » Logged
« Reply #2 on: August 15, 2023, 11:25:41 AM »
Did you mess with the ground connection?
Jim500
North Royalton Oh
« Reply #3 on: August 15, 2023, 11:40:30 AM »
Thank you for replying. is there only one? The head light comes on and goes out when I hit the starter.
Jim500
North Royalton Oh
« Reply #4 on: August 15, 2023, 12:16:55 PM »
Anyone looking for a Valkyrie that doesn't run????  CHEAP!!!
f-Stop
'98 Standard named Hildr
Driftwood, Texas
« Reply #5 on: August 15, 2023, 02:14:49 PM »
From your description of the headlight turning off when you hit the starter switch and nothing happening -- plus if you know your battery is good -- it almost sounds like a dirty starter switch.  Common issue with Hondas that have this style of starter switch.
 Smiley
WintrSol
Florissant, MO
« Reply #6 on: August 15, 2023, 02:57:09 PM »
Headlight is designed to turn off when you press the starter button, so nearly all power goes to starter motor. If it isn't the switch, look elsewhere, like the starter relay.
RonW
Newport Beach
« Reply #7 on: August 15, 2023, 04:42:23 PM »
is transmission in neutral?
2000 Valkyrie Tourer
Jim500
North Royalton Oh
« Reply #8 on: August 15, 2023, 06:03:00 PM »
Took the switch apart and jumped it. Starter worked but no spark to the spark plugs with the ignition on, its like there is a circuit dead.
« Last Edit: August 15, 2023, 08:48:48 PM by Jim500 » Logged
RonW
Newport Beach
« Reply #9 on: August 15, 2023, 09:18:37 PM »
You jumped directly from the battery to the starter motor? Anyways, since the starter motor is okay, the culprit might be the safety interlock circuit. The neutral switch if transmission was in neutral. I assume the keybox was ON. I like to jump the starter motor at the starter relay.
WintrSol
Florissant, MO
« Reply #10 on: August 16, 2023, 09:46:35 AM »
I read that as two problems.
1.the switch wasn't working, so didn't activate the relay. So, jumped the contacts at the switch and starter turned, proving a switch problem. OP, did I read that right?
2.there is some problem with the ignition system.
