February 11, 2026, 04:55:02 PM *
Author Topic: Broken right side engine mount  (Read 2239 times)
cogenguy
Bakersfield CA
« on: August 17, 2023, 12:37:56 PM »
I was involved in and accident a few months ago on my 2000 tourer.  Bike went down on its right side and the engine guard was damaged and also bent the subframe it was attached to.  It also broke the engine mount on that side.  It looks as though the engine case is split.  Is there anyway to repair what is broke(cast aluminum) or will this make the bike unrepairable unless I find and engine for sale somewhere?  Is this engine the same as the Goldwings in that year?
« Reply #1 on: August 17, 2023, 02:36:22 PM »
Sounds like the bike is really totaled nit just insurance speak totaled
pancho
Bonanza Arkansas
« Reply #2 on: August 17, 2023, 03:43:25 PM »
Cast aluminum can certainly be repaired, but since it is a mount that is broken, I would be looking for a motor case if I was going to put it back on the road.
psckam
Elmira, New York
« Reply #3 on: August 17, 2023, 04:54:23 PM »
looks like at least a half dozen engine cases on ebay they appears to be less than a  c note.
« Reply #4 on: August 17, 2023, 05:44:20 PM »
'97-'00 goldwing engine are the ones to get, they received some internal engine upgrades to match the valkyrie engine. also then u will have a better OD 5th gear.
Jims99
Ormond Beach Fl.
« Reply #5 on: August 18, 2023, 04:39:38 AM »
I had bought a valk that was laid down. As I was going through fixing everything (already put a lot in) I noticed the right motor mount was broke. Took it to a reliable welder and they welded it back together. You can tell by looking, but nice strong joint. Not sure I would bother if the case is cracked. If not bad, a good welder can fix. Cast is not easy, biggest thing is must be supper clean. Good luck.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
« Reply #6 on: August 18, 2023, 05:46:30 PM »
Anything and almost everything can be repaired, at a price. Is it worth it?
I'm all for replacing the motor, GW will work, but it's not a Valkyrie. Better or worse engine? Like mentioned, the 97-00 is same/better. I don't know, but you'll have reverse if you can get it working on the Valkyrie, personally I would go GW, cheaper.
