December 28, 2025, 07:32:47 AM *
Author Topic: Rough Shifing--Slave Cylinder?  (Read 2694 times)
Fazer
« on: October 05, 2023, 11:40:35 AM »
I know Valks are a bit clunky and noisy shifting due to the square cut gears, but mine seems like it is getting worse.  Wondering if it's not time to take a look at the slave cylinder.  How do you know?  Mine is not leaking.  Fairly recent oil change with Rotella T6, but I could not get 15W-40 and used 5W-40.  Would that make a difference?  I have not checked the bushing in the clutch handle, but will soon.  Brakes and clutch bled a month ago.
Nothing in moderation...
da prez
Wilmot Wi
« Reply #1 on: October 05, 2023, 01:22:54 PM »
Hold the clutch lever in with the bike on level surface engine running bike in gear. If it starts to creep , clutch slave or master cylinder is leaking.  If no creeping , consider a shifter buddy.
                        da prez
DragonRdr
Gardner, MA
« Reply #2 on: October 05, 2023, 01:31:52 PM »
Yep, Shifter Buddy smoothed out the shifting on my bike.  cooldude Easy to install and worth the investment.
2000 Valkyrie Interstate
1994 Goldwing Interstate
Gondul
VRCC #408
Central Florida
« Reply #3 on: October 05, 2023, 02:15:19 PM »
These bikes require a firm shift... safe yourself $50
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
« Reply #4 on: October 05, 2023, 02:23:33 PM »
My guess is the brass bushing in your clutch handle is worn and sloppy
« Reply #5 on: October 06, 2023, 06:25:33 AM »
All GL1500 transmission gears are Straight Cut Gears.  The GW 1500 only the 5th OD gear is actually a helical cut gear for noise reduction.
Is the Valkyrie 5th gear also helical cut?, I don't know, I have never been able to verify that. however due to EPA noise regs I surmise it is also.
Slave cylinder needs fluid change timeline the same as brake fluid.
h13man
Indiana NW Central Flatlands
« Reply #6 on: October 06, 2023, 06:36:24 AM »
I tried using T6 "new formula" (EPA changes) after using it since 2007 and I had noisier engine and funky shifting. Changed out @ 100 mi. to Valvoline 4T and that lasted 3000 mi. before breaking down. Been using Mobil 1 w/o issues.
« Last Edit: October 06, 2023, 06:39:31 AM by h13man » Logged
mark81
Cincinnati Ohio
« Reply #7 on: October 06, 2023, 11:55:27 AM »
I've been using 5w40 t6 for the past 40k on the yellow bike with no issues. Been using rotella in all my bikes and everything else I've owned for 20 years. Like others I have the shifter buddy installed on both valkyries. It did improve the shift feel and I recommend it. Starting really noticing the shift slop around 70k. Especially going into second.
1997 Honda Valkyrie
1981 Honda CB750 Custom
steveB (VRCC UK)
« Reply #8 on: October 07, 2023, 02:42:13 AM »
5th gear is helical cut.
Fazer
« Reply #9 on: October 11, 2023, 11:24:04 AM »
Thanks everyone.  I have the shifter buddy and just received from Partzilla a new clutch lever bushing.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #10 on: October 14, 2023, 07:12:27 AM »
I cannot see how 'straight cut' or 'helical cut' gears can affect shifting. The only moving parts while  shifting are the dogs.
So many roads, so little time
VRCC # 5258
« Reply #11 on: October 15, 2023, 04:03:41 AM »
https://www.goldwingfacts.com/threads/gl1500-why-to-rebuild-clutch-slave-cylinder.372581/
https://www.goldwingfacts.com/threads/slave-cylinder-gl1500.675160/#post-6000573
« Reply #12 on: October 16, 2023, 05:23:59 AM »
The bushing is just pressed in. You have to tap it out the correct way. Look and maybe measure go from the small side to the larger
