December 28, 2025, 07:32:52 AM *
Author Topic: Cannot remove damper rod in right front shock  (Read 2031 times)
Joe333x
Boston
« on: December 16, 2023, 11:31:32 PM »
My damper rod bolt just keeps spinning, cant get it out, or tighten it back it. Bottom part of the rod is spinning with no way to hold it. I tried completely reassembling the fork tube and even with the oil and spring pressure it spins. Any advice?
« Reply #1 on: December 17, 2023, 03:45:08 AM »
Seems like you're already doing what they suggest in the manual...
Speedy Coop
South Wales, New York
« Reply #2 on: December 17, 2023, 04:48:51 AM »
Are you using a impact gun ?  That has worked for me in the past.
Joe333x
Boston
« Reply #3 on: December 17, 2023, 07:39:25 AM »
Going to pick one up today, batteries crap the bed on the one I had. Getting a corded one this time, had enough with batteries that cost more than tools.
Yes I was following the manual and that was the first thing I tried.
Joe333x
Boston
« Reply #4 on: December 17, 2023, 11:24:34 AM »
Update! Went and picked up and impact and impact hex ends at harbor freight. At first I was very discouraged because it didnt was to come out vertical upside down. Some suggested it needed to be vertical so I put it vertical and kept good pressure with a little bounce on it and it came out! Actually yelled out loud in excitement since I though I might end up having to drill it out. Thank you everyone for your advice!
