November 11, 2025, 11:07:21 AM *
Author Topic: Brake question.  (Read 1614 times)
Tx Bohemian
Victoria, Tx
« on: January 08, 2024, 08:28:48 AM »
Can anyone tell me how thick the front and rear brake pads are when they're new?
'99 standard.
I'm looking my bike over for a trip coming up and haven't checked my brakes in a while.
Preliminary looking, without taking anything apart, the front looks pretty thin.
I bought a used '99 Sentra (72K miles) and when I inspected the rear shoes, they looked really thin! But when I got a new set, they were just as thin.
I put another 175K miles on the car and never changed them.
Al
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: January 08, 2024, 09:40:04 AM »
There is a 'gap' or 'gaps' in the pads that shows minimum thickness. If they are worn to those gaps, replace. Some folks wear pads quickly, others not so much. If in doubt, replace them.
WintrSol
Florissant, MO
« Reply #2 on: January 08, 2024, 09:45:48 AM »
Most sites say you should replace at 3mm, and absolute minimum before failure is 2mm. If you can see that slot, use your best judgement.
F6Dave
« Reply #3 on: January 08, 2024, 01:11:29 PM »
At the 'hot Inzane' in 2012, I noticed a worn out front pad as I was pulling into Eureka Springs. Big BF had one set of OEM pads left, which I bought and changed on the spot in the parking lot. It takes only a few minutes as most of us know.
Now when I change pads I keep two good old ones and put them in the saddlebag. They never wear equally and a single pad is all it takes to get you home in most cases.
Tx Bohemian
Victoria, Tx
« Reply #4 on: January 08, 2024, 05:36:52 PM »
Thanks guys!!
Al
« Reply #5 on: January 09, 2024, 05:37:45 AM »
Thanks guys!!
calipers fully retracted rear pads fit. rear pads are 10mm thk, which is only 1.5mm thicker than front.
I/S OEM rear pads are lowest priced.
https://www.valkyrieforum.com/bbs/index.php/topic,93000.0.html
« Last Edit: January 09, 2024, 07:20:42 AM by 98valk » Logged
