Grey wolf oz
« on: February 04, 2024, 09:22:37 AM » |
Hey team,
I’m not sure if the two events are related, how ever, on a ride a few weeks back, I ended up on a road with a lot of loose gravel and a very steep incline, The bike went down, first left then right then upright and once my heart. Rate settled,,,,,, on we go,
Now I have a oil leak Largely on the right side of the outer timing belt cover Engine bar over the horn mount Temp sender under Black hose under the front of the motor Also some oil on the fork seal
I can not see the source of the leak so it has me screeching my head a bit,
I’m gonna go ahead and acknowledge fork seal needs work, but I am more worried about the oil on the engine, and where it has likely come from
Any suggestions ?
Luke
« Reply #1 on: February 04, 2024, 09:56:43 AM » |
Likely from the leaking fork seal blowing back on the engine. Am I understanding correctly that you crashed twice ?
« Last Edit: February 04, 2024, 12:16:13 PM by The emperor has no clothes »
Grey wolf oz
« Reply #2 on: February 04, 2024, 10:08:15 AM » |
One crash,,,,,,, down left down right and stood back up,,,,,, Kept riding,
I think most of this is from that event, but,, well not sure,
WintrSol
« Reply #3 on: February 04, 2024, 11:52:20 AM » |
Can you post a photo? One would really help with this.
98 Honda Valkyrie GL1500CT Tourer Photo of my FIL Jack, in honor of his WWII service
« Reply #4 on: February 04, 2024, 02:43:48 PM » |
The thing to do (if you are not sure where the leak is), is clean everything up well, then take a ride and when you get back, use a flashlight and take your time, and discover the leak. Remember gravity runs down hill, so when you find oil, look above it and follow the shiny trail to the source.
Having found it, fix it or get it fixed.
I had one Valk that leaked a small amount of oil from one fork seal. It was never very much, and I just kept riding it (and cleaning it) for some years before finally fixing it. I was in no hurry since the fork function and bike handling was never compromised one little bit.
« Reply #5 on: February 04, 2024, 03:33:11 PM » |
I was always having the right fork interment leaking, usually temp related. sometimes fork was always leaking slightly while riding. so turns out I wasn't installing front wheel exactly like it should be. so along with this thread https://www.valkyrieforum.com/bbs/index.php/topic,116905.0.htmlI came up with this procedure and leakage stopped for some time, Torqued down the axle without pinch bolts and fender bolts tighten. Then tighten caliper and right side pinch bolts. This put the guide line on the axle just touching the speedo housing, this is a std/tourer and not at the fork as the VTX sites show. The wheel spins freely for many turns. will do the brake fork bounce and tighten the pinch and fender bolts after finishing up the brakes. however it started leaking a more than it should so I added some ATP AT-205 re-seal to fork fluid about 1/4 oz to each fork. 500 miles later, zero leakage. at 1k miles now still dry. now 3+k miles still bone dry. many fork oils already have some seal sweller in them, I know the Amsoil fluid I use does, so I just added some more and a better highly rated product. https://atpautomotive.com/fluids-and-additives/re-sealscotty kilmer approved. https://www.youtube.com/results?search_query=Scotty+Kilmer+at-205 https://www.valkyrieforum.com/bbs/index.php/topic,126543.0.html how to stop leaking fork seals
Grey wolf oz
« Reply #6 on: February 05, 2024, 02:21:09 AM » |
Shoot me a direct message I can email a photo faster than post one
Grey wolf oz
« Reply #7 on: February 05, 2024, 02:21:52 AM » |
Thanks will do
da prez
« Reply #8 on: February 05, 2024, 06:46:51 AM » |
Just an FYI. When I do a cleanup involving oil , Dawn dish soap mixed 50/50 with water. Spray on , let dry. Respray and hose down with hot water if available. Dawn will not harm most surfaces. If you have oily ducks nearby , you can do them too.  I have been using this method for years. da prez
« Reply #9 on: February 05, 2024, 09:34:15 AM » |
Dawn dish soap is like a miracle product; with so many uses.
Mix it with gas and give your ground dwelling yellow jackets a midnight douche.
Doing it it daylight is a big mistake.
Grey wolf oz
« Reply #10 on: February 05, 2024, 09:41:57 AM » |
Shoot me a direct message I can email a photo faster than post one Thanks looks logical !
