February 11, 2026, 11:24:57 AM *
Author Topic: 00 Interstate Volts from Alternator  (Read 1646 times)
shabelj
« on: May 07, 2024, 01:44:29 PM »
How many volts should Alt. be putting out at idle.  I just had mine replaced and am only getting 11.6 at idle, 12.4-12.6 at 2k rpm.  but getting 13.5-13.7 at highway speeds.  I replaced it with a OEM 95 Goldwing Alt. and clocked the housing?
« Reply #1 on: May 07, 2024, 02:07:21 PM »
some report less than 14V at idle especially if the idle is set below the recommended 900-1000  but as soon as you get under way it should be at or a tad over 14.  If your volt meter is not wired directly to the battery there may be a lower than actual reading but what you said you are showing is not right.
longrider
Vernon, B.C. Canada
« Reply #2 on: May 07, 2024, 10:16:58 PM »
Idle should be around 12.3 depending on the draw.  1200 13.6 give or take.   1500   14.1-14.2
Jims99
Ormond Beach Fl.
« Reply #3 on: May 08, 2024, 04:23:50 AM »
Mine sits at around 13.2 at idle and sits around 13.8-14.1 at highway speeds. Stock with 76k miles.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
« Reply #4 on: May 11, 2024, 06:34:57 PM »
Most likely too late now, but did you do anything else to the Alt before putting it in, like cleaning/blowing out the brushes?
