November 18, 2025, 08:14:12 PM
Alarm System
Topic: Alarm System (Read 4516 times)
X Ring
VRCC #27389, VRCCDS #204
Alarm System
March 09, 2009, 10:00:54 AM »
Decided I need to put an alarm system on my Valk. Anybody have any recommendations?
DFragn
Re: Alarm System
March 09, 2009, 10:16:24 AM »
http://www.internatrix.com/
<$200.00 and is better then or equal to systems running $300.00-$500.00. I've had mine installed for almost 4 years, no complaints.
X Ring
Re: Alarm System
March 09, 2009, 11:09:15 AM »
Thanks!!!
JimL
Naples,FL
Re: Alarm System
March 09, 2009, 11:39:38 AM »
DFragn, interesting and useful info. Just curious were you found space to mount the control unit, sensor and antenna on the Valk?
DFragn
JimL
March 09, 2009, 12:04:34 PM »
I installed the control unit in the tool slot behind the battery. Suggest carving a small opening in the rear turndown of the battery cover & notch the box a bit to run the wiring without pinching.
Speaker & siren are velcro'd to the back side of the coolant overflow.
And, the remote antenna is velcro'd to the rear fender under the passenger seat. I ran its coax along the frame [zip ties] and behind the fender rail. The antenna receives a good remote signal from 80'-100'+ away under there.
DFragn
Oh yeah. I fergot!
March 09, 2009, 12:09:53 PM »
I had mounted the proximity sensor on top of the battery cover. Later I added the OEM Tourer CB that could only go on top of the cover. So I relocated the Proximity sensor to the inside lid of my added I/S trunk. There it doesn't sense well forward of the fairing, but it does successfully register movement from the fairing/bars and rearward.
JimL
Naples,FL
Re: Alarm System
Reply #6 on:
March 09, 2009, 01:21:38 PM »
Good stuff! Thanks for sharing.
Jim
=> InZane XXV
