September 23, 2025, 03:19:33 AM *
Author Topic: shifter problem, big foot!!  (Read 1705 times)
Squatch71
« on: May 18, 2024, 10:28:03 AM »
Hello everyone. I just recently bought a 99 interstate. and I have a problem. I have a size 16 shoe and I am having a hard time shifting. my foot won't fit in-between the valve cover and the shifter.
does anyone have a suggestion that I can resolve this issue?
I thought about getting a piece of pvc and sliding it onto the shifter knob and "extending" it.
thanks in advance
« Reply #1 on: May 18, 2024, 10:41:01 AM »
The shifter from a CB1100 has been known to extend the shifter out and up a bit. Another solution is to cut/grind off the peg from the shifter. Drill a hole and mount an aftermarket shifter from Kuryakin and you could add a spacer to move the shifter out a bit.
DragonRdr
Gardner, MA
« Reply #2 on: May 18, 2024, 10:58:45 AM »
No matter what you do make sure you get and install the Shifter Buddy if you extend the shifter. Here's a link to a post I originated. I installed the Shifter Buddy and I'm really glad I did.  My Interstate shifts a lot smoother and no more shifter slop. It's sold by SCAIN who is a member of the VRCC and you can message him or do a search on FaceBook.
https://www.valkyrieforum.com/bbs/index.php/topic,121161.0.html
« Last Edit: May 18, 2024, 11:00:44 AM by DragonRdr » Logged
2000 Valkyrie Interstate
1994 Goldwing Interstate
« Reply #3 on: May 18, 2024, 01:12:27 PM »
The shift lever is adjustable up and down.  Just unscrew it, pull it off the shaft and put it back where you want it to be.  Yes, a CB1100 shifter can help also.
Squatch71
« Reply #4 on: May 18, 2024, 01:39:56 PM »
thanks again for the feed back, yea i think ill just move the shifter up abit
« Reply #5 on: May 18, 2024, 03:52:14 PM »
Move the shift lever on the splines first.  (I scratched a small line across the output shaft and the lever as a benchmark of where I started, before moving it around).
If that doesn't do it, get a bigger/longer shift rubber to work (the peg on all model Valks was too small, even for small feet).
Until I went with heel-toe shifters (which would be a problem with #16 foot/boot), I made my own longer peg (and stiffened it up somehow, since it was longer than the lever supported).  It was a long time ago.
« Reply #6 on: May 18, 2024, 06:09:28 PM »
Don't you want to move it down a bit to give more room between the lever and the valve cover?
« Last Edit: May 18, 2024, 06:11:08 PM by Willow » Logged
RNFWP
"What color blue is that?"
Greenville, SC
« Reply #7 on: May 18, 2024, 07:34:46 PM »
Maybe someone will add to this... seems like a nighthawk shifter could be used, giving more room at the peg. (has an offset shape?)
psckam
Elmira, New York
« Reply #8 on: May 20, 2024, 04:41:09 AM »
the cb1100 shifter is also longer so the rubber will be closer to the footpeg.
SCain
Rio Rancho, NM
« Reply #9 on: May 20, 2024, 05:54:53 AM »
I usually have several CBR1100XX shifters for sale, I also the make of the Shifter Buddy.
The CBR1100XX Shifter has an offset which brings it out a bit away from the motor, where the OEM shifter does not have an offset.
Send me an email @ scain1520@yahoo.com and I will send you a picture of the two shifters side by side if you are interested.
Thx
Steve
Steve
