September 23, 2025, 03:19:31 AM *
Author Topic: Help with starting issues  (Read 1631 times)
Devinci40
« on: May 26, 2024, 11:32:00 AM »
Hello, I have a 1998 Valkyrie tour the question is sometimes I push the starter button and it does nothing. I push it two or three times the bike will start other times I push the button and it starts right away. Any suggestions?
« Reply #1 on: May 26, 2024, 12:05:55 PM »
Starter button maintenance. Look in shop talk
Jims99
Ormond Beach Fl.
« Reply #2 on: May 27, 2024, 04:12:05 AM »
Agreed
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
« Reply #3 on: May 27, 2024, 08:57:01 AM »
Where are you located?  The starter button maintenance is not hard but a little intimidating the first time. I’ve done several, the most important thing is to make sure the little brass contact is free to move up and down on the little spring or it will malfunction again soon.
Avanti
Stoughton, Wisconsin
« Reply #4 on: May 27, 2024, 02:25:08 PM »
Second important thing. Do not lose the spring.
« Reply #5 on: May 27, 2024, 05:13:32 PM »
[/quote
Add your location into your profile, and the bike.
Good start. Lights go out when you push the button, but the starter doesn't kick in.
2nd possible, would be the starter relay/fuse/connector. Look that one up too. Not likely from what you've described.
