December 28, 2025, 03:31:43 AM *
Author Topic: I've developed a fuel leak  (Read 2285 times)
DeathWishBikerDude
« on: August 02, 2024, 04:06:07 PM »
The outside right carb is leaking fuel while running?
Stuck float?
Taking it apart in the am,would just like some thoughts.
Low mileage bike.
« Reply #1 on: August 02, 2024, 04:35:38 PM »
most likely fuel rail. the end nuts of the thru bolts that hold the carb banks together do come loose. tighten those nuts.
pg 15-7 tech manual
lnstall the rear stay plate and four nuts, and tighten the nuts.
TORQUE: 70 N-m (1.0 kgf-m, 7 Ibf-ft)
Mooskee
Southport NC
« Reply #2 on: August 03, 2024, 10:45:54 AM »
If you want to discuss it, contact me via my web site. Then we can swap phone numbers. It is difficult to offer any kind of effective troubleshooting without hearing all the details.
-mike-
Germany
« Reply #3 on: August 03, 2024, 11:35:20 AM »
pg 15-7 tech manual
Again.... :rolleyes
Would you please keep your habit of repeating unreflected assumptions and feeled "truth" to your favourite playground, the VRCC PaM Board.
There you can shine along with your 3 other mudslinging colleagues.
Your post doesn't meet the experience off ALL others here.
@DeathWishBikerDude: take Moskee's offer. Get qualified help there.
What a shame that reliable tech info has to be communicated by p.m. lately just because some loud and persistent fellows don't get it and can't stop posting B.S.
-mike-
« Last Edit: August 03, 2024, 11:38:22 AM by -mike- » Logged
« Reply #4 on: August 03, 2024, 11:53:08 AM »
pg 15-7 tech manual
Again.... :rolleyes
-mike-
wow! kinda nasty there, -Mike-. what an uneducated attacking comment u made to me and others.
 even the service manual makes reference to check all nuts and bolts.
 -Mike- you disagree with the Honda engineers who wrote the book? u should go badmouth them.
yet u fall for some of the scare tactics some mechanics use to get work who say they need to rebuild all of the carbs when if anything it is only the plastic fuel T's that might need new o-rings.
And you do not know by background with carbs, o-rings and troubleshooting.
Furthermore many have tried my suggestion and reported that the leak/s stopped and they rode on with zero problems.
mine started leaking once during a temp change. I tightened the ends nuts leak stopped and still riding 50k miles later and zero leaks. and for your ignorance the nuts were very slightly loose took about a 1/32 of a turn to tighten and then the LEAK STOPPED!!
I have industrial experience working with o-rings in pneumatic systems under pressure,
 Do you -mike-??
« Last Edit: August 03, 2024, 04:04:22 PM by 98valk » Logged
