January 30, 2026, 09:22:21 AM *
Author Topic: Accessory power block ideas???  (Read 3588 times)
Bounty Hunter
Canton, MI
« on: February 13, 2010, 08:42:06 PM »
I'm looking to install an accessory  power block on my 97 I/S for fog and driving lights, GPS, Gerbings for the wife etc...
Relays may be needed due to power draw from the lights.
I'd like it to be key activated so no power switches get flipped by accident, leaving us with a dead battery at the wrong time.
Thanks for your time
John S.
Bounty Hunter
States that I have ridden in!
John U.
Southern Delaware
« Reply #1 on: February 13, 2010, 10:03:55 PM »
I've been using this one from Electrical Connections: http://www.electricalconnection.com/power-distribution/pplate.htm
It has a relay which is triggered by the accessory plug-in under the right side cover. It also has a connection for a battery charger which is disconnected when the key is turned on.
You can get a ground bus for a 110/220 panel boxfrom Home Depot or Lowes. The one I bought was too long so I cut it in half and used the 2nd piece for another bike.
9Ball
« Reply #2 on: February 14, 2010, 02:41:04 AM »
This is what I installed.  Nice compact package fits under right sidecover on a clear polycarbonate plate I fabricated.   The plate is held in place with tie-wraps so it can be easily removed to access underneath.  The sealed, weatherproof feature makes this location suitable...sorry for the fuzzy picture.
What isn't shown in this picture is the rubber cover that encases and protects the fuses.
I bought mine from Autozone about 3 years ago for about $45.
http://www.painlessperformance.com/webcatalog/largeview.php?SearchField=70213
John
« Last Edit: February 14, 2010, 02:54:22 AM by jrhorton » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Disco
Republic of Texas
« Reply #3 on: February 14, 2010, 07:37:23 AM »
This is the one I got in my stocking.   cooldude   It's not on the bike yet, but soon!
5 Fuses, 8 outputs, 2 Sections (switched & unswitched)
Centech AP-2
« Last Edit: February 14, 2010, 07:41:06 AM by Dave in Frisco (TX) » Logged
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
Madmike
Campbell River BC, Canada
« Reply #4 on: February 14, 2010, 09:52:52 AM »
Centech AP-2
That is a nice looking panel........ be good to post a pic when you get it installed..
Does it have built in relays and just require a battery hookup and ignition status wire or do you need to supply two separate power sources to it for the keyed/unkeyed sections to work??
ptgb
Youngstown, OH
« Reply #5 on: February 14, 2010, 12:19:03 PM »
Here's a good previous thread about this:
http://www.valkyrieforum.com/bbs/index.php/topic,3933.0.html
« Reply #6 on: February 14, 2010, 02:10:14 PM »
I hooked my ap1 up using advice from the VRCC so that it is only hot when the key is on.
I put it here...
« Reply #7 on: February 14, 2010, 03:51:12 PM »
I bought one at auto zone. Some one posted how to do it last summer. Its inside my side cover and i have it secured with a small bungi for easy access behind it.
Madmike
« Reply #8 on: February 14, 2010, 04:06:10 PM »
Thanks... there are some good links in the thread you pointed out.
captsharky
Been riding Honda since 1972.
Sunrise, Florida
« Reply #9 on: February 15, 2010, 07:35:19 AM »
I just got one of there, to nistall on the Valk, for the Faring radio, and power socket.
 Some will say it's over kill, but I went with the bussman one the VTX, and I was not that happy.
Clear insulating cover with label recesses accept Small Format Labels
Cover Satisfies ABYC/USCG requirements for insulation
Tin-plated copper buses and fuse clips give 30 Amperes rating per circuit
Accepts ATO and ATC fast acting blade fuses
20 write-on circuit labels included
http://bluesea.com/category/5/21/productline/126
2001 Valk black Interstate,
1998 T Cobra light bar, Corbin seats  Tank bib, baker air wings, lockable hard bags, luggage rack and trunk. Woody's faring, cruise throttle lock.
junior
new hampshire
« Reply #10 on: February 16, 2010, 01:47:10 AM »
better overkill than a harness meltdown
