iulian
« on: September 08, 2024, 03:08:29 PM » |
I would like to know the right part number for the Side Switch for my Valkyrie 1500/1997, looks like the #35070-MZ0-B00 is not available anymore, is anything else that can be fitted on? Thanks
« Reply #1 on: September 08, 2024, 04:00:23 PM » |
Most switches fail due to dirt. Remove the switch and spay contact cleaner in the tiny hole in the housing. Blow it out and test with an ohm meter.
DIGGER
« Reply #2 on: September 08, 2024, 04:46:50 PM » |
iulian
« Reply #3 on: September 08, 2024, 10:51:28 PM » |
Seems unavailable.
h13man
Indiana NW Central Flatlands
« Reply #4 on: September 10, 2024, 06:04:30 AM » |
Honda SWITCH SET, SIDE STAND 35070-MZ0-B00 RevZilla https://www.revzilla.com › ... › Honda OEM Parts Shop RevZilla for your Honda SWITCH SET, SIDE STAND 35070-MZ0-B00 today! FREE Shipping, No-Hassle Returns, and Top-Rated Customer Service from REAL Riders! $41.00 · Free 2–3 day delivery · 90-day returns
« Reply #5 on: September 10, 2024, 06:19:00 AM » |
I searched all my sources and they are all "Not Available". Hay  Jimmyt
DIGGER
« Reply #6 on: September 11, 2024, 08:07:37 PM » |
I guess you could bypass it. Just better make sure you are in neutral or it could just take off if in gear...
« Reply #7 on: September 12, 2024, 06:12:33 AM » |
Yea, just like a Harley. If you know, you know. Hay  Jimmyt
DIGGER
« Reply #8 on: September 12, 2024, 06:18:53 AM » |
Can a kickstand off of a VTX of the same year (or other Honda) be used?
Avanti
« Reply #9 on: September 12, 2024, 06:24:26 AM » |
I am wondering if the difference between Honda side stand switches are only the wire connector.
GiG
NEAR the "In 'n' Out Burger"
« Reply #10 on: September 12, 2024, 02:29:35 PM » |
Very easy to defeat, did it to all my bikes… swap terminals No need to remove the switch for contact cleaner, just spray the thing
There are probably dozens of automotive switches that could serve this function 12V low power
Everything is - Nothing is .
When you come to a fork in the road - TAKE IT! (send it to OSS)
This isn’t Rocket Surgery
DIGGER
« Reply #11 on: September 12, 2024, 02:48:57 PM » |
Question....i think there are 3 wires??? Going to that switch. Why so?
GiG
« Reply #12 on: September 12, 2024, 02:55:54 PM » |
Yes, going by spotty memory… black, green, yellow swap yellow / green at terminal to defeat Gnd / sw open - sw closed Stand up / stand down
« Last Edit: September 12, 2024, 03:03:37 PM by GiG »
Avanti
« Reply #13 on: September 12, 2024, 03:25:08 PM » |
Three wires for Standard and Tour because they have a light indicator and two wires for the Interstate because it does not.
