November 05, 2025, 04:28:04 AM *
Author Topic: Can only start up my 1998 Valk in Neutral  (Read 1550 times)
Mike C
Crystal Lake
« on: November 08, 2024, 03:26:56 PM »
My 1998 Valk will only start in the neutral gear, absolutely no other way.  I've tried every other means.   Kick stand up or down, any other gear will not start.  Not sure what my next step is.
Any ideas >> Thanks!
« Reply #1 on: November 08, 2024, 04:02:19 PM »
My guess is the kickstand cutoff switch needs cleaned or work.
Up or down, the switch thinks it's down.
« Reply #2 on: November 08, 2024, 04:15:33 PM »
Or the bushing in the clutch lever is worn, not depressing the switch. Do you hear it click when you pull the clutch?
« Last Edit: November 08, 2024, 06:03:56 PM by Chrisj CMA » Logged
Valker
Wahoo!!!!
Texas Panhandle
« Reply #3 on: November 08, 2024, 05:27:05 PM »
Clutch switch could also need replaced.
Mike C
Crystal Lake
« Reply #4 on: November 09, 2024, 06:13:32 AM »
Jess, Chrius and Valker >> Thanks for your opinions - I appreciate it.
Where is the kickstand cutoff switch located?  I'll check the manual.
I can also check the bushing.  Wouldn't I be having issues with changing gears if the bushing were bad?
I'll replace the clutch switch if the bushing is good, and after checking for the kickstand cutoff switch.
Thanks again.
RP#62
Gilbert, AZ
« Reply #5 on: November 09, 2024, 07:56:45 AM »
You could probably take the bushing out and the clutch would work ok, but there'd be so much slop that the microswitch on the clutch handle wouldn't make and complete the circuit to the starter relay.
-RP
GiG
NEAR the "In 'n' Out Burger"
« Reply #6 on: November 09, 2024, 08:09:03 AM »
Hey, Mike: a little troubleshooting or permanent modification- take a short 2-3” wire & crimp female terminations on each end. Slide the females over the 2 prongs of the KS Switch- she should start in any gear. Easily reversible, but I’ve left my bikes that was - KS Sw is defeated  Roll Eyes
Everything is - Nothing is .
(send it to OSS)
This isn’t Rocket Surgery
