February 11, 2026, 07:22:41 AM *
Author Topic: Petcock strainer question  (Read 4048 times)
High Desert
« on: December 01, 2024, 04:45:02 PM »
Greetings!  I took my petcock off the tank the filter did not come out with it.  How do you remove it?  It obviously needs replacing as the petcock was fouled.
Joe333x
Boston
« Reply #1 on: December 01, 2024, 07:50:51 PM »
Do you mean the plastic net sheathing wrapped around it is  came off and is in the tank? I guess you just have to fish it out with something. A new petcock comes with a new filter. To save some money and have one less vacuum line you can replace it with the Honda non vacuum petcock part #16950-MAL-603. You just need to make sure you shut it off obviously. Here's a photo of my old one and new ones you can see the ethanol does a number on the plastic.
« Last Edit: December 02, 2024, 06:12:31 AM by Joe333x » Logged
Pluggy
NC
« Reply #2 on: December 02, 2024, 12:40:30 AM »
The base of the filter tube can get stuck in the hole.  I use an EZ-out to gently grab it so it comes out.
The filter is available as a part.  https://www.partzilla.com/product/honda/16952-MZ0-003?ref=84992df13e16df5f6344dd38d4e689b733436bfe
Not so sure ethanol is the culprit.  Those filters turned brown like that before ethanol was blended into gasoline.
« Last Edit: December 02, 2024, 12:49:49 AM by Pluggy » Logged
Speedy Coop
South Wales, New York
« Reply #3 on: December 02, 2024, 05:05:01 AM »
I have used a tap of appropriate size lightly screwed in to remove the strainer.
« Reply #4 on: December 02, 2024, 06:17:10 AM »
If it’s at the hole like normal simply grab it with a needle nose pliers. Works every time for me
High Desert
« Reply #5 on: December 02, 2024, 09:32:45 AM »
Thanks all!  Very helpful, every answer.  This is an amazing forum.  It helps make Valkyrie ownership as easy and fun as it is.
YellingatClouds48
« Reply #6 on: December 30, 2024, 10:27:04 AM »
is the Interstate strainer the same as the Tourer/Standard?  The part number for the Interstate strainer is no longer available.  The tour/standard is still available.   Anyone have experience with this?
Timbo1
Tulsa, Ok.
« Reply #7 on: December 30, 2024, 05:11:36 PM »
The part # for the Petcock Screen Set is different between Standard / Tourer and the Interstate.  Megazip.net shows both available.
Megazip
Standard / Tourer 16952-MZ0-003
Interstate 16952-MBY-003
« Last Edit: December 30, 2024, 05:33:52 PM by Timbo1 » Logged
« Reply #8 on: December 31, 2024, 06:45:26 PM »
they are different and affects how much the reserve is.  search for the thread that has the details.
« Reply #9 on: January 01, 2025, 07:48:41 AM »
Just a question,
I have a 2003 Valkyrie Standard.  I have never played with the Petcock.  I have seen several "things" about replacing the petcock to ensure it will work when needed.
So, my question is, well are:
1.  Can some provide me the correct part number or a replacement petcock that will not use the vacuum line. I assume that is the best option.  I saw this part number above.
Non vacuum petcock part #16950-MAL-603
2.  Is there a tutorial that explains how to do this replacement?  If so, can someone provide a link?
Thanks.
« Reply #10 on: January 01, 2025, 08:04:38 AM »
Just a question,
Thanks.
some threads I bookmarked over the yrs
https://www.valkyrieforum.com/bbs/index.php/topic,128455.0.html
https://www.valkyrieforum.com/bbs/index.php/topic,119537.0.html  uses oem handle
https://www.valkyrieforum.com/bbs/index.php/topic,37577.0.html  modify oem for no vacuum.
ridingron
Orlando
« Reply #11 on: January 01, 2025, 05:33:41 PM »
Is the brass tube and screen the same as the Valk one?
The height of the brass tube determines when to switch to reserve, correct?
Pluggy
NC
« Reply #12 on: January 02, 2025, 05:19:29 PM »
The vacuum valve is a safety feature, not a convenience feature.  If the bike is down in an accident, the "tip over" switch stops the engine and there is no vacuum to the valve.  The fuel flow stops and can't drain out through the carbs. The owner's manual tells us to turn off the (vacuum) valve when shutting off the engine, so we should be doing that already.
The vacuum line from #6 cylinder to the fuel valve is easy to replace.  The "cover set" that replaces the valve diaphragm is also easy to replace.  These are things to consider before you retire the vacuum valve.
« Last Edit: January 02, 2025, 05:33:19 PM by Pluggy » Logged
Joe333x
Boston
« Reply #13 on: January 03, 2025, 08:57:46 PM »
I believe it has a slightly smaller reserve. The strainer might be taller too but it fits no problem, ran it all last year.
« Last Edit: January 03, 2025, 09:00:09 PM by Joe333x » Logged
« Reply #14 on: January 08, 2025, 07:47:08 AM »
The IS and Tourer/Standard tanks are different sizes.  I think this is the reason for 2 different petcocks.  Maybe so they both have the "same" reserve as the tank sizes are different.
My $.01875
Hay  Cool
« Reply #15 on: January 08, 2025, 08:49:19 AM »
Fuel tank capacity, service manual pg 1-4
GL1500CICT    20 liters (5.3 US gal, 4.4 Imp gal)
GL1500CF       26 liters (6.9 US gal, 5.7 Imp gal)
Fuel tank reserve capacity
GL1500C/CT    4.3 liters (1 .14 US gal, 0.95 Imp gal}
GL1500CF       4.0 liters (1.06 US gal, 0.88 Imp gal)
