February 11, 2026, 07:23:18 AM *
Author Topic: Fuel Delivery Issues  (Read 2509 times)
Peteg
« on: February 07, 2025, 07:45:23 AM »
Yesterday cruising along on flat road my 1500 asked to be put on reserve about a gallon too early. Once on reserve and after fill up with the fuel valve back to normal all was good. I suspect I have a partial blockage in the strainer, fuel valve, or vent? Is there anything else I should be looking at?
« Reply #1 on: February 07, 2025, 08:49:30 AM »
if OEM petcock vacuum diaphragm is wearing out restricting flow.  more fuel in tank creates more head pressure overcoming the bad diaphragm
https://www.valkyrieforum.com/bbs/index.php/topic,37577.0.html
https://www.valkyrieforum.com/bbs/index.php/topic,128455.0.html
https://www.valkyrieforum.com/bbs/index.php/topic,119537.0.html
« Reply #2 on: February 07, 2025, 09:30:53 AM »
+1 for suspecting early signs of petcock failure. That’s how my headaches started. It got worse. I rebuild the vacuum side with a cover set. Then the selector knob side wore out. Scrapped it and went with a Pingel. No more issues for the last 15 years
« Reply #3 on: February 07, 2025, 09:35:46 AM »
It does sound very similar to what happens with a fuel line with a dip in it.  If one has replaced the fuel line (as with a quick disconnect unit) it can result in the occasional air bubble that needs extra pressure.
Peteg
« Reply #4 on: February 07, 2025, 02:37:44 PM »
Thanks, the fuel line looks good, no quick disconnect, so I'm leaning toward the petcock valve. I like the diaphragm valve - getting forgetful in my old age. I'll make sure the tank vent is good and likely spend the money for a new petcock and strainer kit. Honda Parts Nation and Partzilla point me toward a Honda 16950-MZO-033 petcock kit but then Partzilla says it doesn't fit my bike - the picture looks great. Can anyone tell me if the available Honda part fits? Also the K&L 347385-461249 at parts giant seems to be direct replacement at about 1/2 the cost of the Honda part. Any opinions on the K&L?
« Last Edit: February 07, 2025, 02:54:01 PM by Peteg » Logged
« Reply #5 on: February 07, 2025, 03:48:09 PM »
just get the rebuild kit instead of paying $$$ for a new petcock. easy to rebuild.
« Reply #6 on: February 07, 2025, 03:55:31 PM »
I agree. The cover set will buy you some time. When it fails again just scrap it and get a Pingel
« Reply #7 on: February 07, 2025, 04:02:43 PM »
rebuilt mine 20yrs ago still going strong, however I also installed a snubber in the vacuum line at the same time to soften the high pulsation to the diaphragm when on/off on the throttle during shifts, esp., during higher rpm shifts.
Joe333x
Boston
« Reply #8 on: February 08, 2025, 07:56:50 AM »
Non vacuum petcock is also an option. I'm running this on my bike along with an electric fuel shut off. Now I have no vacuum lines on my bike that can fail. Part #16950-MAL-603.
Peteg
« Reply #9 on: February 08, 2025, 03:53:54 PM »
Thanks all for this great information! It was 84 degrees in North Texas today, so I started by running the gas down in the tank and functionally testing the vent. Not a bad job cooldude
