Scalper
« on: April 24, 2025, 04:50:03 PM » |
Hey guys! After 5 years of riding 1300 VTX's, I bought a 1999 Valkyrie Tourer. This thing is sweet! And I'm pretty sure the previous owner was a member here because the keychain has your logo.
I'm overwhelmed with all of the things I need to do, and the things I want to do with it!
If you just bought a used Valkyrie, what are some of the first things you'd do to get it ready to ride, and what are some components you'd check for wear or common failure points I need to be aware of? I'm sure there's a thread around here somewhere listing all of the things I'm asking... If you can send me that direction, that would be great!
LadyDraco
TISE
« Reply #1 on: April 24, 2025, 05:41:40 PM » |
Greetings  I would say the biggest thing is the rear end ,the Pinion cup . Make sure it gets lube in the weep holes . Other than that oil changes, filter, air filter, Drain the drool. Enjoy the power.
Life is what you make of it~If it don't fit make alterations... One does not speak unless one knows. Never underestimate the power of a woman ! It's a Poor Craftsman who blames their Tools ! This is the way
Scalper
« Reply #2 on: April 24, 2025, 07:08:04 PM » |
Could you offer more information about what could go wrong with the drive in that situation?
« Reply #3 on: April 24, 2025, 07:16:36 PM » |
First you want good tires and brakes. And good gas (non ethanol if you can get it).
What did the seller tell you about maintenance?
Oil, filter, coolant?
« Reply #4 on: April 24, 2025, 08:09:18 PM » |
Peruse the 1500 tech board. EVERYTHING and ANYTHING you wanna know bout Valkyries is in there. Problems encountered problems solved. Once tou git er sorted out RIDE it like you Stole it! RIDE SAFE.
« Reply #5 on: April 25, 2025, 04:13:45 AM » |
Congratulations and welcome  If you give us more info on the bike and your location, maybe a picture, someone might recognize your new girl friend and might be able to provide maintenance info. If the previous owner was/is a member here, than most likely they serviced the rear drive at last tire change. It's standard procedure with everyone here, or at least should be. I'd ride her for a while before tearing into her, assuming all fluids, tires and brakes are good.
h13man
Indiana NW Central Flatlands
« Reply #6 on: April 25, 2025, 04:43:12 AM » |
OEM manual and this link that has been most useful to me. http://www.valkyrieriders.com/shoptalk/
Pluggy
« Reply #7 on: April 25, 2025, 05:17:55 AM » |
Hello, Scalper. Yes, first get a service manual. It is possible that a previous owner made modifications to the bike. A good first step is to compare the wiring, exhaust and vacuum systems to the manual to find out what you actually have.
« Reply #8 on: April 25, 2025, 05:26:45 AM » |
The rear end drive splines and driveshaft splines need a liberal greasing periodically. It is often times ignored. Putting back together with the correct sequence is critical
h13man
« Reply #9 on: April 26, 2025, 07:02:29 AM » |
Like Chrisj CMA suggested and be sure change the "3" o'rings. The better o'rings (Viton) come from Redeye. They're awesome supply place for Valks. I've using their shock bushings, final drive o'rings (buy a extra set  ) and intake o'rings so far. These bikes are very easy to work on bikes don't be intimidated. To me, it just like working on pre 72' SB Chevy. Change All fluids. You're dealing with appx. 25 yr. old rubber components which are expiring due to age. I've dealt with fork seals, brakelines and shifter seal the past 6 mos. https://redeye.ecrater.com/category.php
« Reply #10 on: April 28, 2025, 05:00:52 AM » |
If you bought John Schmidt's bike, I'm sure you're in better shape then most that buy a used bike. John's a stickler when it comes to maintenance, so if you have his service history, you are good to go and just need to follow the Honda maintenance schedule. I'm sure John would answer any questions you may have, saving you time and money. If it's not John's bike, that's a different story.
« Reply #11 on: April 28, 2025, 05:50:41 AM » |
Imagine driving your car, truck etc which no gear oil in the differential. Imagine your pinion gear teeth turning into a rusty red dust.
« Reply #12 on: April 29, 2025, 10:16:52 AM » |
Totally agree on John's bike. That thing is ready to ride anywhere in the country you desire. Hay  Jimmyt
t-man403
Valk-a-maniac
Calgary, Alberta, Canada.
« Reply #13 on: April 30, 2025, 08:13:12 PM » |
Just ride it and if it breaks, it’s easy to fix.
« Reply #14 on: May 01, 2025, 05:17:01 AM » |
In the immortal words of @Daniel Meyer...... "Ride it hard, fix it when it breaks!" Hay  Jimmyt
Sweet Cheeks
« Reply #15 on: May 03, 2025, 08:57:34 AM » |
I also moved from a VTX 1300 to a Valkyrie. You’ll never look back! Welcome!
Janice
I am pretty sure my last words will be ... “Well crap! That didn’t work!”
2004 VTX 1300 (sold) 1998 Tourer 2003 Standard
