November 04, 2025, 09:58:42 PM *
Author Topic: I should be riding, but another project  (Read 658 times)
« on: April 28, 2025, 06:37:50 AM »
Home ownership, a joy and a nightmare! The windows in my house are builder grade vinyl that should never be sold to anyone. But that’s what has happened to thousands of homes and now good windows are a rare commodity. I have a twin window in my basement that needed replacement for a variety of reasons but I have not found a window that suits me.
So last fall when I came across a high quality French patio door at a greatly reduced price that I could make fit, I jumped on it.
It has been leaning against a wall in my basement all winter, that is until last week. It was demolition time!
The brick removal took more time than I thought. But these brick are no longer available so I wanted to salvage as many as possible. A diamond blade and a masonry hammer drill came into play along with a 2 lb hammer and a wide chisel
The window removal was simple by comparison but still had to be cut out with a reciprocal saw as the nails holding it in were behind the brick. The frame wasn’t worth salvaging anyway.
No turning back now.
That’s a 2x6 wall , another reason I bought the door as it came with the wide jamb.
I put everything  back in with pressure treated lumber, wasn’t much anyway.
Closed back in with still a lot of shimming and adjusting. French doors can be a pain.
Sure does look different from the inside. Lots of trim work left to do inside and out, but for now, let it rain!
Another big plus! I can now roll my bike into the living area like Chris does the Cobra bike.
« Reply #1 on: April 28, 2025, 11:13:49 AM »
Congrats on a nice project.   Experience and the right tools sure makes for a well done project.
Waiting to see those pics of the bike pulling through that French Door.  Wink
« Reply #2 on: April 28, 2025, 11:29:26 AM »
Pics will be forthcoming but sadly I’m not sure a trike will fit though. I haven’t measured the maximum inside width the the total outside frame dimensions are a fraction under 59” so at least 1 3/4 - to 2” less than that. But the garage is right next door.
« Reply #3 on: April 28, 2025, 01:18:45 PM »
Very nice work John.  cooldude
I know I couldn't do it.
I'm lucky enough to have a local window mfr very close-by, and they make good stuff and stand behind it.
I had a kitchen window of theirs giving me some trouble, and drove over to talk to them.
The guy said we will fix it for you (no charge), but I can show you exactly what you need to do, and you only need a flathead screwdriver.  He showed me on a demonstrator window in the showroom.  I came home and fixed it in 3 minutes.  My kind of project.   Grin
« Reply #4 on: April 28, 2025, 02:19:45 PM »
    KNOWING which end of any tool to hold IS the trick shot!  Roll Eyes BUT happy both y'all got er done!  2funny                                                 RIDE SAFE.
« Reply #5 on: April 28, 2025, 02:31:48 PM »
My experience here in Richmond is that even the smallest of jobs ends with 3 zeros before the decimal point. So for now if I can’t do it myself it just won’t be done. One day I will have to modify my position on that, but not quite yet. The other point for me is that after coughing up those zeros and other attached numbers, I won’t be satisfied with the results, been there, done that.
