November 04, 2025, 07:23:11 PM
Not starting in gear
Topic: Not starting in gear (Read 739 times)
ciddriver
Nanaimo B.C. Canada
May 05, 2025, 11:43:32 AM »
Hi, took my 99 interstate out of storage and first ride yesterday and it would start in neutral but not in gear with clutch pulled in, it’s a trike. Took the switch off clutch lever and cleaned the points but didn’t make any difference. Going to get a replacement one tomorrow but wondered if there is anything else that I should look at.
Challenger
Re: Not starting in gear
May 05, 2025, 04:03:22 PM »
I would check the kick stand switch. If the kick stand was removed when the bike was triked, double check how they wired around it.
GiG
NEAR the "In 'n' Out Burger"
May 05, 2025, 04:37:06 PM »
Rewire so it appears NEUTRAL always.
Jumper 2 prongs (probably #2 & #3 - from memory…
) all my bikes set this way
If: you hit starter while in gear - Jump!
Everything is - Nothing is .
(send it to OSS)
This isn’t Rocket Surgery
May 05, 2025, 04:54:53 PM »
Quote from: ciddriver on May 05, 2025, 11:43:32 AM
... if there is anything else that I should look at.
You have the right direction.
ciddriver
Nanaimo B.C. Canada
May 05, 2025, 10:40:12 PM »
Thanks, will check it out.
Thunderbolt
Worthington Springs FL.
May 06, 2025, 10:56:17 AM »
Been a while since I had a Valkyrie but I think I remember that the pivot point would wear and not engage the switch that made the connection. Maybe a new clutch lever fixed it.
Reply #6 on:
May 06, 2025, 01:38:31 PM »
Quote from: Challenger on May 05, 2025, 04:03:22 PM
This would be my bet too.
longrider
Vernon, B.C. Canada
Reply #7 on:
May 07, 2025, 06:24:10 AM »
Check the clutch switch and and the two spade connections located on the left handlebar beside the pivot.
=> InZane XXV
