November 20, 2025, 09:55:01 PM
Stock shock adjustment
Topic: Stock shock adjustment (Read 1786 times)
wdvalk
Katy Texas
February 21, 2010, 05:23:50 AM »
Which way do you yurn them to stiffen them?
doubletee
VRCC # 22269
Fort Wayne, IN
Re: Stock shock adjustment
February 21, 2010, 06:35:01 AM »
Quote from: wdvalk on February 21, 2010, 05:23:50 AM
Higher the number, the more preload, hence the stiffer. There's a mark on the lower portion of the shock that aligns with the numbers (1-5) on the upper portion.
Ratdog
Somewhere out West, Which way did I go?
February 21, 2010, 08:25:24 AM »
And... when you get to "5" and (for some reason) decide you want to go to another setting... continue on to "1" (turning the same direction all the time). Don't try going "the other direction". And... when it does settle back to "1"... it's going to make a sharp "BANG" as the shock lengthens... nothing to worry you. It's just doing what it's supposed to do.
Make yourselves sheep, and the wolves will eat you. - Benjamin Franklin. If it ain't Zesty, it's only a two-tone.
=> InZane XXV
