February 11, 2026, 05:35:41 AM *
Author Topic: Strange Problem  (Read 4424 times)
dan7uk
Louisville, Kentucky
« on: June 26, 2025, 05:30:14 AM »
While riding, when I release the throttle and pull in the clutch to shift, the bike keeps a fast rpm for a couple of seconds before dropping to normal.  Does this when going thru the gears, up shifting or down shifting.
I adjusted the throttle free play and it had no effect.  Any suggestions?
« Last Edit: June 26, 2025, 05:33:39 AM by dan7uk » Logged
« Reply #1 on: June 26, 2025, 05:45:45 AM »
idle mixture screws or and mostly there is a vacuum link. PAIRS valve vacuum hoses or the normally intake manifold unused vacuum port caps are leaking.
http://www.factorypro.com/tech/tech_tuning_procedures/tuning_carbtune,CV,lower_rpm_engines.html
h13man
Indiana NW Central Flatlands
« Reply #2 on: June 26, 2025, 08:27:39 AM »
I'd say a vacuum leak. I'd replace all lines as they are 30'ish years old and depending on care/storage in its previous life.
Mooskee
Southport NC
« Reply #3 on: June 26, 2025, 10:47:08 AM »
+1 on most likely a vacuum leak.
WintrSol
Florissant, MO
« Reply #4 on: June 26, 2025, 02:04:30 PM »
Also +1 on vacuum leak. Lean engines tend to 'throttle hang', and when the vacuum spikes, even a tiny leak will contribute to this. You can test this without moving; raise rpm to about 3k and quickly close the throttle. It should quickly return to idle, if not, it is too lean. If it drops lower than comes back, too rich, but it doesn't sound like the problem here.
dan7uk
« Reply #5 on: June 26, 2025, 04:32:02 PM »
This bike is a 99 interstate and I picked it up about two months ago.  I'm sure the bike hasn't been desmog in its 26 years.  Seems everyone who posted is in agreement on a vacuum leak.  I owned a 99 standard Valkyrie about 15 years ago and I put a desmog kit in it just for precaution.  I guess I will be putting one in my current one.
Thanks for all who posted, I never thought of a vacuum leak could be causing my problem, are the red eye desmog kits still available?  Have a link?
« Reply #6 on: June 26, 2025, 06:02:02 PM »
see my post how I did the desmog. first time I did the heads were on the engine. this was a set of ported heads so I did them before I installed the heads.
https://www.valkyrieforum.com/bbs/index.php/topic,105991.0.html
dan7uk
« Reply #7 on: June 27, 2025, 04:06:22 AM »
98 Valk, I looked at your attachment didn't see anything about desog just work on your heads.
SCain
Rio Rancho, NM
« Reply #8 on: June 27, 2025, 04:59:34 AM »
Look at the signature line for Mooskee, he is a VRCC vendor, sells a De-Smog kit on his web site.
Steve
« Reply #9 on: June 27, 2025, 02:17:40 PM »
scroll down to Reply #15 and #16
here is my top desmog plugs. Used shortened 9/16" bolts. Fill the holes with quicksteel. Then some hi-temp silicone and install the bolts.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #10 on: July 03, 2025, 05:27:18 AM »
Make sure that the carb butterlys are actually closing quickly and not hanging up a little when the throttle is closes.
So many roads, so little time
VRCC # 5258
Pluggy
NC
« Reply #11 on: July 03, 2025, 05:50:07 AM »
Yes.  Stuck "Butterflies" was a problem on my 4 cylinder Honda.  That bike has no vacuum system to fail.
Mooskee
Southport NC
« Reply #12 on: July 03, 2025, 09:46:08 AM »
Routing of the throttle cables can cause it to close slowly upon letting off.
Does it still do it if you twist the throttle closed?
WintrSol
Florissant, MO
« Reply #13 on: July 03, 2025, 10:37:31 AM »
As can what you choose to lubricate them.
dan7uk
« Reply #14 on: July 05, 2025, 03:55:26 AM »
I will check them when I am installing a desmog kit next week.
