December 27, 2025, 11:16:26 PM *
Author Topic: Small amount of fuel visible near valves  (Read 842 times)
wjamesfl
Tampa, FL
« on: August 01, 2025, 09:48:53 AM »
Hi all. New 98 Standard Valk owner, purchased the bike 3 weeks ago, first time owning a carbureted bike so excuse my ignorance. The previous owner stated carbs were rebuilt 2 years ago but he was rarely ever able to ride it due to health issues, the bike has 8,500 miles on it. I originally posted this on FB group but this seems a better place to post it.
The bike does run and I have been running B12 through it. I am currently replacing intake manifold o-rings now with viton-b ones.
While doing that, Ive noticed in intake #3, #4, and #6 have  what looks like a small amount of gas pooled in there by the valve. Is this expected? Or do I have an issue in the carbs. I tried starting the bike with the plugs disconnected as I read to do that, but its such a small amount I guess, that none even squirted out.
Haven't seen any leaking externally. #5 looks dry.
So I left left the intake manifolds off overnight. This morning I felt around the flange/outlets on the carbs where the rubber and manifolds connect. They all feel bone dry, no obvious sign of leaking from carbs. Is this a problem or just normal to have a little fuel there after running the bike. Attached picture.
« Last Edit: August 01, 2025, 09:51:26 AM by wjamesfl » Logged
« Reply #1 on: August 01, 2025, 10:37:44 AM »
That is fuel leaking around the bottom of the intake runners. The viton o-rings should fix the leak.
Hay  Cool
« Reply #2 on: August 01, 2025, 11:29:52 AM »
If you have gas pooled on top of a closed valve, that’s a hydrolock waiting to happen. You have a stuck needle in that carburetor and possibly a malfunctioning petcock. Ignore this at the risk of totaling your bike. The repair parts are not available
wjamesfl
Tampa, FL
« Reply #3 on: August 01, 2025, 11:37:31 AM »
I just replaced the petcock with a brand new KEI HIN OEM petcock last week. It sounds like I will be pulling the carbs off today.
« Last Edit: August 01, 2025, 11:44:01 AM by wjamesfl » Logged
