Valker
Wahoo!!!!
Texas Panhandle
« on: August 07, 2025, 09:06:12 PM » |
After 26 years and a quarter million miles I had my forks completely gutted and rebuilt with their cartridges and added a set of YSS shocks. I just got the bike back together and took it for a 35 mile test ride over very familiar roads. Tremendous difference in the ride quality and handling. Very expensive, but well worth it to me. It's like a new bike. It's the best addition I've done.
mello dude
Dayton Ohio
« Reply #1 on: August 08, 2025, 01:21:20 AM » |
Thumbs up for Traxxion Dynamics  Jeez the forum needs a like button.
* There's someone in my head, but it's not me....... * Mr. Murphy was an optimist.... * There's a very fine line between Insanity and Genius..... * My get up and go, must have got up and went.....
« Reply #2 on: August 08, 2025, 03:53:12 AM » |
"Tremendous difference in the ride quality and handling."
so what does this mean exactly? or does it just let you ride a 750lb motorcycle faster than before?
I run progressive springs played with fork fluid type, weight and level and installed I/S shocks on my std with I/S tank, triple clamps and saddle bags.
reducing the trail number via the I/S triple clamps, smaller 130/90-17 and taller C/T 205/65-16 great enhanced the responsiveness, of the bike. reducing the trail number makes the biggest difference.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #3 on: August 08, 2025, 05:12:12 AM » |
I tried a lot of those same things except for the Interstate triple clamps. Yes, it is much more stable in corners, yes, I can ride them faster. The ride thing feels like the sharp edges on bumps have now been rounded off. It rode like an old one ton pickup to me, now it feels more like a newer F-150 King Ranch. I also own some ST1300s which have always ridden smoother and handled better than the Valks. The new suspension makes the Valk handle as well as or better than the ST and almost equals the ride quality.
« Reply #4 on: August 08, 2025, 06:26:30 AM » |
I tried a lot of those same things except for the Interstate triple clamps. Yes, it is much more stable in corners, yes, I can ride them faster. The ride thing feels like the sharp edges on bumps have now been rounded off. It rode like an old one ton pickup to me, now it feels more like a newer F-150 King Ranch. I also own some ST1300s which have always ridden smoother and handled better than the Valks. The new suspension makes the Valk handle as well as or better than the ST and almost equals the ride quality.  "The ride thing feels like the sharp edges on bumps have now been rounded off." yep using 7.5 wt fork oil did that for me.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #5 on: August 08, 2025, 07:03:57 AM » |
I tried a lot of those same things except for the Interstate triple clamps. Yes, it is much more stable in corners, yes, I can ride them faster. The ride thing feels like the sharp edges on bumps have now been rounded off. It rode like an old one ton pickup to me, now it feels more like a newer F-150 King Ranch. I also own some ST1300s which have always ridden smoother and handled better than the Valks. The new suspension makes the Valk handle as well as or better than the ST and almost equals the ride quality.  "The ride thing feels like the sharp edges on bumps have now been rounded off." yep using 7.5 wt fork oil did that for me. Tried that.
« Reply #6 on: August 08, 2025, 07:18:56 PM » |
is that an I/S or std/tourer?
Valker
Wahoo!!!!
Texas Panhandle
« Reply #7 on: August 08, 2025, 07:34:54 PM » |
Mine is a 98 Tourer.
Disco
Republic of Texas
« Reply #8 on: August 09, 2025, 02:06:40 PM » |
I've been around a while and have never heard that there are differences between the IS triple clamps and those of the Standard and Tourer. They appear to have different part numbers, but Grok says the rake and trail are the same. What am I missing? TIA
2000 Bumblebee Tourer, 98 Yellow & Cream Tourer, 97 Rescue blower bike 22 CRF450RL, 19 BMW R1250RT 78 CB550K, 07 Helix 71 MT50 Trailhopper .jpg) VRCC 27,916 IBA 44,783
« Reply #9 on: August 09, 2025, 05:28:29 PM » |
I've been around a while and have never heard that there are differences between the IS triple clamps and those of the Standard and Tourer. They appear to have different part numbers, but Grok says the rake and trail are the same. What am I missing? TIA yes rake and trail are the same. the I/S clamp has 1/32 more offset than the std/tourer clamps. So then Honda changed the fork stem rake of the I/S to make the trail the same. All due to the fairing weight on the I/S. Service manual does list the different numbers btwn both
Peteg
« Reply #10 on: August 10, 2025, 01:47:53 PM » |
Valker, have you loaded her up yet for touring? If not I think you'll be smiling even more when you do. I only have the YSS shocks on the rear. My bike only has 55,000 and I'm still happy with the front. I'm sure I don't ride as aggressively as you either. The springs are really stiff progessives. I think they're 45-60 anyway it's stamped on the side. I believe the conversion is something like 250 / 350 (I have the exact numbers in a file if you care) while an interstate spring is 140 / 200. The available preload adjustment for load sag on a 5 step interstate shock is less than 5/8" and that's assuming level 1 unloaded sag is good for you. Your rear shocks probably came setup with about a 1/4" of preload over unloaded length. Easy to check if you care. Jack her up and back off the adjusting collar until the spring is loose - 4 turns = 1/4". So you could probably add an 1 1/8" more preload for 2 up heavy load riding. Bring your spare bearings and tools LOL. If the load is tight and you dial in the rebound damping to kill the spring bounce I think you'll find she handles almost like the loads not there. Be careful if you ever really add 1 1/8" of additional preload as you have infinite adjustment and you don't want to add so much preload that the spring coil bottoms before the bump stop. I found mine continued to get better for about 2,000 miles. I have lower back issues and found for the first 2,000 miles I needed to pretty much back off those initial 4 turns. Once things loosened up I probably put 3 turns back. I dial the rebound damping for comfort - I back it off as far as I can and turn it back up if there's bouncing on the bumps. I find the rebound follows preload - so if you really tighten down the springs for load you will need lots of rebound damping to stop the stiff springs from catapulting you after the bump. I carry a pair of the rubber coated knit work gloves with my shock tools. If you keep the threads lubricated you'll probably be able to grab the adjustment collar and spring with both hands and make your preload adjustments without the bar. Sometimes the rebound will turn so always verify and adjust rebound after preload. I typically adjust the preload in my shop with a jack under the bike before a trip. If she begins to bounce or wander in the curves with all the weight I just add a few more clicks of rebound damping and the world is good.
Have fun, ride safe!
Joe333x
« Reply #11 on: August 13, 2025, 05:27:27 PM » |
I had a 12.5 inch 412 blow out on me today going over one of those stupid man hole covers that sank into the ground. They were the standard, not heavy duty ones. Do I go with a 412HD or the YSS? The ride height of the 12.5 was absolutely perfect for me, progressive is being stingy on the warranty because I bought them last year on Amazon, even though the seller was Amazon, not a third party seller.
Nightflight99
« Reply #12 on: August 13, 2025, 07:26:11 PM » |
I've had Progressive shocks on multiple bikes, but always found them to be rather mediocre. In my experience, Ohlins, Penske, and K-Tech shocks have been phenomenal, but they are pricey and to my knowledge none of them seem to produce units that are compatible with the Valkyrie. When I redid the suspension on my Standard, I went with shocks from Shock Factory [ https://shock-factory.fr/en/], along with RaceTech fork springs. This setup significantly improved the handling of the bike without breaking the bank (too badly). In fact, I liked it so much that I went with the same brand of rear shocks for two other bikes, including my Interstate. My Rocket III still has Progressive shocks on it (a relict from the previous owner), but I plan on replacing them as well.
2000 Honda Valkyrie Interstate 2001 Honda Valkyrie Standard 2010 Triumph Street Triple 2013 Suzuki DR650 2017 Triumph Rocket III Roadster 2016 KTM 690 Enduro R 2021 Triumph Rocket 3 GT
Joe333x
« Reply #13 on: August 13, 2025, 07:44:02 PM » |
I just looked them up, what's the height on them?
Nightflight99
« Reply #14 on: August 14, 2025, 04:12:20 PM » |
They should be stock height (either 12.5" or 13" -- I have bags in the way that keep me from taking an accurate measurement).
Peteg
« Reply #15 on: August 15, 2025, 11:21:18 AM » |
YSS will work. With the height adjustment all the way down (how I ride them with my 29" inseam) they're about 12 3/8", but they ride higher than my old light spring 12.5's. Anyway to me they're just like 12.5's. They'll be shorter than 13's at full height adjustment but again they'll feel higher with a couple of turns of preload on the stiff springs. Like 12.5's they only have a 2.5" stroke, but they're so good for the money IMO it doesn't matter.
Joe333x
« Reply #16 on: August 15, 2025, 06:21:06 PM » |
I spoke to Dan and they are adjustable from 12.4” to 12.8. I think I'll be picking up a pair soon especially after the snarky customer service from Progressive between the lady who answers the phone and the guy that answered the emails. A shock fails in roughly 3000 miles and they will do absolutely anything to get out of a warranty repair. You'd think they'd want to stand behind their products and figure out why the shock failed. Instead they just want you to buy a new pair, best they would do is offer a $100 discount on a new pair. Rather spend the extra $100 on the YSS and hopefully they last longer than 3000 miles.
Joe333x
« Reply #17 on: August 31, 2025, 09:01:56 AM » |
Installed the YSS and have a couple days in the saddle on them and they are great! So much better than the progressive 412s I had that made me cringe everytime I went over a bump. They don't look as pretty but they are also behind the bags anyways.
