January 14, 2026, 11:31:02 AM *
Author Topic: Breakaway Cruise Control  (Read 4323 times)
robin
Get on it and RIDE!!
Hardwick NJ
« on: February 22, 2010, 01:41:55 PM »
Anybody using it with Iso grips and how do you like it?
Jack
Benton, Arkansas
« Reply #1 on: February 22, 2010, 01:44:25 PM »
I have it on my wife's VTX and it works great.  High quality product.
NITRO
Eau Claire, WI
« Reply #2 on: February 22, 2010, 02:27:33 PM »
I had heard that they won't work with Iso Grips, so I sold my grips to Alph (I wasn't giving up that expensive lock!). We compared the stock grip to the iso grip and they look identical. Can't say for sure, but I'm guessing they would work just fine with the brakeaway throttle lock.
When in doubt, ride.
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« Reply #3 on: February 22, 2010, 03:30:42 PM »
Great product.   cooldude   I use it with the ISO grips with nary a problem.    Wink
« Reply #4 on: February 22, 2010, 03:55:26 PM »
What is it? something similar to the Vista?
Ron
Carefree AZ
« Reply #5 on: February 22, 2010, 04:23:18 PM »
No problem using breakaway and Iso grips.
Ride Safe
Ron
2017 Goldwing / Nav Trike
2014 Valkyrie
robin
Hardwick NJ
« Reply #6 on: February 22, 2010, 04:32:20 PM »
Hey Ron i have the control covers on both sides do you think that would be a problem with clearance ?
I have that same fast color blk/orange
« Last Edit: February 22, 2010, 04:34:41 PM by robin » Logged
Ron
Carefree AZ
« Reply #7 on: February 22, 2010, 05:01:16 PM »
I don't run arcoss to many of those BLK/orange Valks in my travels. My wife refers to my bike as my Halloween bike.
I do not know about the control covers, but I would assume that they are the same size as stock. You might want to email BigBF. He is the one that installed the breakaway and is very knowledgeable on Valkyries.
98valk@bigbf.com
Ride Safe
Ron
2014 Valkyrie
Gear Jammer
Magnolia, Texas
« Reply #8 on: February 22, 2010, 05:19:31 PM »
Fudgie,  It is a mechanical throttle lock like the Vista, but it has a cam that releases the lock when you touch the brake lever.  It also has a squarish button on bottom to set the cruise, and the long slender release button above that.  I had the Vista previously, but this one is much better if for no other reason than safety concerns.  You don't have to "think" to release the throttle if something happens to cause you to "grab" the brake,,,it's automatically released.
T.P.
Apple Valley, Minnesota.
« Reply #9 on: February 22, 2010, 06:03:02 PM »
I have had that combo since early 2006 and love it. I had to turn down the ISO grip flange to (1.80)to fit inside the first BWs'........but I had heard they will now fit the ISO grips flush to the switch hsg. T.P.
alph
Eau Claire, WI.
« Reply #10 on: February 22, 2010, 07:05:27 PM »
yeap, it does!
andym
Middeltown, De
« Reply #11 on: February 22, 2010, 08:04:24 PM »
Had it on my I/S and sold it on ebay......It works well ..sort of hard to adjust just right during the install, but once it is set up, it wokrs great. The only reason I sold it is that like all other throttle locks it doesnt really regulate the speeds on hills and such. Robin if I remeber  correctly, you are in Northern NJ and it is fairly mountainous there and I know you do some long distance riding , so give some thought to how well that FIXED throttle will serve you. PS- You can always tweek it up and down , but then why have a cruise control? I found that I used it when I had to take my right hand off the throttle for a few minutes but then I was rignt back on doing adjustments. Maybe just cause Im a picky pain the the butt engineer (per my wife, LOL) but I am now installing an Aduiovox cruise control , and hope to try it out this weekend and PS the Audiovox is less $. I heard they are discontinuing the Audiovox so if you opt to go for that , do it soon (Amazon.com -Css100)
Ratdog
Somewhere out West, Which way did I go?
« Reply #12 on: February 22, 2010, 10:07:58 PM »
Works well for me... I also have the BBP chromed switch housings.  No problem with 'em.
Make yourselves sheep, and the wolves will eat you. - Benjamin Franklin. If it ain't Zesty, it's only a two-tone.
Momz
ABATE, AMA, & MRF rep.
« Reply #13 on: February 23, 2010, 05:24:40 AM »
Sure is expensive! But a better product than the "Vista Cruise".
I had a VC on my 98 standard and I still have a VC on my I/S.
I like the "rooster & Lock" far better than the VC but it won't work on the I/S.
I now have a C&L on my standard,...a simple and elegant solution, but it doesn't turn off like the "Brakeaway".
ALWAYS QUESTION AUTHORITY!
MAD6Gun
New Haven IN
« Reply #14 on: February 23, 2010, 06:04:42 AM »
 I have the breakaway and ISO grips as well. It take a little tweeking to get right but not to bad. Works well and best of all looks great too. Since  I redid my bike and show it sometimes I wanted something that would look good and function well on top of it.
cutter
Plantersville, Texas
« Reply #15 on: February 23, 2010, 07:42:30 AM »
Breakaway..... does it work on an I/S? and who carries it?
RLD
'99 I/S Red/Black
Eden Prairie, MN
« Reply #16 on: February 23, 2010, 07:56:38 AM »
http://www.brakeawayproducts.com/
I am installing it right now on my 99 i/s. It also will work with heated grips that have the internal wiring, for example: Heat demons.
Removing my Throttle Meister's for the heated grip reason, if anyone's interested in them, drop me a line. They work great, just incompatible with internal heated grips.
Dress for the slide, not the ride. ATGATT
VRCC #2505
cutter
« Reply #17 on: February 23, 2010, 08:48:44 AM »
 $$$ Shocked got sticker shocked!   Thanks for the link.
Garland
#618
Hendersonville NC
« Reply #18 on: February 25, 2010, 08:45:47 AM »
I have one I am no longer using. I paid about $200 for it, will sell for $85 if anyone would like one. I was very happy with it, but ended up installing a MCcruise control instead.  I had it installed with the Kury grips, worked fine.
« Reply #19 on: February 25, 2010, 09:14:41 AM »
Here is what I use on both ISs.  Just a throttle lock (not electronic cruise control), but beautiful billet and easy to install.  Cheaper than Brakeaway.  There is no auto shutoff on hitting the brake, but you really don't need that.  You adjust them to enough tension to hold the throttle, but you can manually override them to kill the throttle against minor resistance (or flip off the cam lock lever).
Work perfectly with Kury ISO grips.
http://www.madcorider.com/cam-lock_honda_cruisers.html
Used in combination with the Kury throttle boss on the ISO grips, this is a nice setup.
« Last Edit: February 25, 2010, 09:18:57 AM by Jess from VA » Logged
Buster
Wild Wonderful West Virginia
Talcott, West Virginia
« Reply #20 on: February 25, 2010, 12:57:00 PM »
Hey Garland, if you still have the Breakaway I'd like to have it.
Buster
T.P.
« Reply #21 on: February 25, 2010, 01:29:00 PM »
Check your "my messages"  T.P.
