January 30, 2026, 10:53:53 AM *
Author Topic: Tourer conversion to Interstate  (Read 2170 times)
Cascadecruiser
« on: February 23, 2010, 02:46:31 PM »
I have a Tourer model. I bought the Interstate trunk with the mounting brackets. However, the brackets do not line up. Is there a difference in the frame between the 2 models? Or is there a spacer that will compensate for the gap? The seller of the trunk said that the bracket parts were all there.
The brackets are several inches off on each side of the bike.
« Reply #1 on: February 23, 2010, 02:53:21 PM »
Need a little more information, a picture(s) would be even better. I don't quite follow what you're referring to. If you have a digital camera, take some shots and describe what or where your problem is with those brackets.
Also, do you have the side fender rails for an I/S? You need those to mount the brackets.
« Reply #2 on: February 23, 2010, 03:01:20 PM »
It will mount the bike below is a 1998 Standard with 1999 saddlebags and a 2001 Interstate trunk.
Momz
ABATE, AMA, & MRF rep.
« Reply #3 on: February 23, 2010, 03:01:58 PM »
Cascadecruiser,
You will need the Interstate fender struts to mount the trunk.
I have a pair that is practecly new.
E-mail me at:dukenjoey@ yahoo.com if your interested.
ALWAYS QUESTION AUTHORITY!
MP
North Dakota
« Reply #4 on: February 23, 2010, 04:49:12 PM »
As above, you need IS fenders rails to work with the trunk.
MP
"Ridin' with Cycho"
