January 30, 2026, 10:54:32 AM *
Author Topic: Starting I/S  (Read 2842 times)
MP
North Dakota
« on: February 24, 2010, 05:42:40 AM »
Just got an 2001 I/S.  Went to take off, still too cold, and killed the engine.  It would not attempt to start until I put it in neutral.  Kickstand was up.
Shouldn't it start with kickstand up, in gear, clutch pulled in?
As soon as I put it in neutral, it started fine.
MP
"Ridin' with Cycho"
Brovietnam
« Reply #1 on: February 24, 2010, 05:46:39 AM »
All the Valkyries "shoud" start as you described.  Your bike might have been setting to the point that the contacts need to be cleaned, and there are several.  Sometimes the kickstand spring in the switch will not have enough force to open that circuit.  Sometimes the clutch needs adjusted.  I would also make sure the battery is fully charged.
MP
North Dakota
« Reply #2 on: February 24, 2010, 05:50:35 AM »
Starts real good, fires right up as soon as put in neutral.  So, do not believe it is a kickstand switch problem. Is there a switch on the clutch, that lets it start with the clutch pulled, verses not starting in gear?
MP
"Ridin' with Cycho"
Daniel Meyer
The State of confusion.
« Reply #3 on: February 24, 2010, 06:06:26 AM »
Yes, there is a clutch switch. It's right up there on the handle. It's common for it's tip to wear down and ALSO for the bushing in the clutch lever to wear to the point where it won't activate the switch. It could also be unplugged.
Easy to check out.
CUAgain,
Daniel Meyer
Ratdog
Somewhere out West, Which way did I go?
« Reply #4 on: February 24, 2010, 09:00:28 AM »
MP
With the engine off, and in a relatively quiet setting... pull in the clutch and listen.  You should hear a faint/mettalic "ping" or "click".  If you do NOT hear it... then the clutch switch needs replaced.  It's about a $7 part and takes about five minutes to change out... a bit longer if you take the time to do a little cleaning, schmooieing, and such.
Make yourselves sheep, and the wolves will eat you. - Benjamin Franklin. If it ain't Zesty, it's only a two-tone.
MP
North Dakota
« Reply #5 on: February 24, 2010, 10:53:41 AM »
Thanks.  I will check the switch when I get a chance.  I put the gl1800 wide adjustable levers on, and they come with a new bushing, so that should not be it.
MP
"Ridin' with Cycho"
Tinman
Manvel Tx
« Reply #6 on: February 24, 2010, 11:32:09 AM »
I put the wide chrome levers on to. Found that they had just a slight bind in them and would not return quite all the way. A little emery cloth and clean and a regrease the pivot pin and all was well.
If that is the problem make sure you do not remove to much as to shorten the life of the bushing.
« Reply #7 on: February 24, 2010, 04:16:28 PM »
MP
Now we just got the problem.
You have to trim those GL1800 levers just a tad to get everything in that clutch switch to work.        It is a lot easier to diagnose when we get all the changes, mods and or etc.      Mainly the last thing ya did before it failed.    LOL      angel
MP
North Dakota
« Reply #8 on: February 24, 2010, 04:22:51 PM »
Had no problem with the ones I put on my 97.  I will check it out though.  If I push the lever open, then try to start, that should tell me?
What I should do is just bypass the switch.  Then could start in gear.  Since it is a sidecar rig, cannot fall over!  LOL
MP
"Ridin' with Cycho"
« Reply #9 on: February 24, 2010, 04:33:58 PM »
It is just a little ridge up by the bolt hole....   I'm assuming the ones you got were like mine.
It doesn't let the lever fully push the switch in when pulled.
My 97 never needed it either, but the set we put on my biddies 2000 we had to trim.    Only have to trim 1 lever.    Who knows maybe my brass bushing was worn enough to not bother..      Wouldn't know now as it is back stock.    Grandson knocked it over Christmas day and broke the end off of the clutch lever.    No, he didn't get his arse warmed up.    He is only 7, and between his dad and I we can not figure out how the 4377 he knocked MGM over.
Kingbee
VRCC# 576
Northern Illinois
MP
« Reply #10 on: February 24, 2010, 06:25:51 PM »
Like was said, listen for the switch click. You may have to adjust the lever setting, depending on what grips you're using.  I had a cranky switch once. I enlarged the mounting screw hole, so I could slightly move the switch closer to the lever.  That worked for me.
LISTEN FOR THE CLICK
1999 Interstate
2000 Interstate
2004 Rune
MP
North Dakota
« Reply #11 on: February 25, 2010, 05:28:59 AM »
Thanks, guys.
MP
"Ridin' with Cycho"
MP
North Dakota
« Reply #12 on: February 26, 2010, 09:12:23 AM »
I checked, the switch does click.  And I can get it started in gear now.  I believe the problem was cold.  I was outside at aobut 10 degrees.  Switch may be a little sticky too.  When warmed up in garage, works, but do need to fully pull in the clutch lever.
MP
"Ridin' with Cycho"
