January 30, 2026, 10:53:49 AM *
Author Topic: HANDLEBAR GRIPS  (Read 3478 times)
Poor Ol Harry
Baytown,TX. East of Houston
« on: February 24, 2010, 08:05:48 AM »
Now I want to change grips ,but not sure how to remove the stock ones without tearing {throtle pipe} UP?2000 IS.
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: February 24, 2010, 08:34:40 AM »
The chrome cap should unscrew from the grip.  Using compressed air, and one of those pointy hose attachments, squirt air under the rubber portion of the grip.  Go at it from the grip end, and by the switch housing...  Sometimes it will puff the rubber up, releasing the glue, and they come right off.  Other times, a razor blade is your friend  Undecided
Black Dog
Don't you know...
Poor Ol Harry
« Reply #2 on: February 24, 2010, 08:44:13 AM »
Boy ! Dog you are full of it!
                            Thanks Harry
« Reply #3 on: February 24, 2010, 11:23:27 AM »
Yep, slice them off. Keep the end caps.  Wink
« Reply #4 on: February 24, 2010, 05:03:52 PM »
If you don't have compressed air, the best tool for getting grips off (you want to save) is an ice pick.  Screw caps off as above, slide the ice pick in, stick the thin nozzle on a can of WD 40 or brake cleaner alcohol in next to the ice pick and squirt.  Work at 12, 3, 6 and 9 O'clock till they come loose.  With the OE grips, I just take a utility knife and slice them lengthwise and throw them in the round file.  You'll want to reuse the OE throttle sleeve.
alph
Eau Claire, WI.
« Reply #5 on: February 24, 2010, 11:40:38 PM »
i got a bottle of WD-40, pushed the tube up as far as i could and sprayed, let it set for a few minutes, then twisted it back and fourth.  came right off with no problem.
make sure you clean off the WD-40 with some rubbing alchohol before reaplying the new grips.
al.
i went with the Kuryakyn Iso grips, love 'em.
