January 14, 2026, 11:30:22 AM *
Author Topic: I need some boots that don't melt on my pipes!  (Read 4058 times)
D.Tater
Jacksonville, FL
« on: February 24, 2010, 07:57:08 PM »
I just spent that last hour cleaning the melted boot heal off my 2Brother's pipes.  Angry
Does anyone know a decent boot mfg. that makes a boot that doesn't melt to the hot pipes?
I would prefer a smooth sole over a rugged sole.
Thanks.
David
'97 Standard
Brad
Reno, Nevada
« Reply #1 on: February 24, 2010, 10:48:25 PM »
Not sure of any sole material that wont leave a mark on a hot pipe.....might try going bare foot  Smiley
Jack
Benton, Arkansas
« Reply #2 on: February 25, 2010, 04:51:06 AM »
Leather soles???
MNBill
Southern Minnesota
« Reply #3 on: February 25, 2010, 05:03:25 AM »
You use the oven cleaner trick to get it off??
MNBill
SE Minnesota
D.Tater
Jacksonville, FL
« Reply #4 on: February 25, 2010, 06:13:08 AM »
Being originally from TN I resemble that remark.... Grin
I have seen nuts rid'n sport bikes with flip flops before.
I did some research, I think Chippewa makes some boots with rubber soles that won't melt.
David
'97 Standard
Mikey
Winona, MN
« Reply #5 on: February 25, 2010, 06:19:39 AM »
Cowboy Boots!!!
Remember folks, street lights timed for 35 mph are also timed for 70 mph
VRCC# 30782
« Reply #6 on: February 25, 2010, 06:24:04 AM »
You sure don't want smooth and/or leather soled boots for riding.
Try floorboards... I don't think I can touch my pipes with my boots
« Reply #7 on: February 25, 2010, 06:44:00 AM »
If they are Cobra's you can......
I wear Red Wings.........   They mark a little, but nothing like my old boots did.
D.Tater
Jacksonville, FL
« Reply #8 on: February 25, 2010, 08:03:13 AM »
Smooth would be to slippery, I love walking on carpet with new leather soled dress shoes.
It's like walking on ice.
With the 2Brother's pipes you defiantly can touch them. I wear a size 11.5 boot and my heal seems to be in constant contact.
I don't know if there is enough room for floorboards with the the 2BRS pipes.
I though about wrapping that section of pipe with header pipe wrap, but after some googling that might not be a great idea, holding moisture, rusting the pipes...any thoughts?
« Last Edit: February 25, 2010, 08:09:06 AM by D.Tater » Logged
David
'97 Standard
Ratdog
Somewhere out West, Which way did I go?
« Reply #9 on: February 25, 2010, 08:14:08 AM »
You're on the right track... keep cleaning those pipes.  When you get tired of doing that... you'll learn to keep yer hooves off of 'em.  Trust me... with a 13EE... I understand the concept of training yourself to be mindful of hoof placement.  The ironic part is... the only burn marks on my pipes are from when a passenger laid her boot heels on the pipes... AFTER I'd taken the time to explain to her to keep her heels on the floorboards... and "WHY"... and got the "I've ridden lots of times" speech.
Make yourselves sheep, and the wolves will eat you. - Benjamin Franklin. If it ain't Zesty, it's only a two-tone.
« Reply #10 on: February 25, 2010, 08:38:14 AM »
I run OE pipes and didn't know the others resulted in boot contact.
I think what I'd do, with pegs or boards, is try to cobble up a piece of L-shaped flatstock to make my own heat shield.  Not attached to the pipe, but mounted to a peg or floorboard mount, or maybe even the frame.   Something that would hold the boot heel off the pipes.  If you look at a Harley parts site, you will see they sell heel cups, usually mounted to the rear of a floorboard, a sort of raised lip that prevents the boot heel from sliding over and contacting the pipes.
I suppose you could also use peg extensions that held the pegs out farther, but this would reduce lean angle (unacceptable to me).
Something like these in principle:
http://www.heelguard.com/
http://www.chopperscycle.com/BAGGER/Floorboards/Carl-Miles-Heel-Guard-p7257792.html
http://www.thefind.com/cars/info-heel-guard-peg
« Last Edit: February 25, 2010, 08:42:35 AM by Jess from VA » Logged
« Reply #11 on: February 25, 2010, 02:41:54 PM »
Can you make a heal plate and screw it to your heal of your boots? Sorta like cowboy boot heal and toe gaurds. Hell get your handle stamped in'm. I believe HD boots have their logo stamped on metal on the heal. I think it would be the cleanest way to go.
