January 30, 2026, 12:29:13 PM *
Author Topic: Shifter peg  (Read 2592 times)
Scooter6
« on: March 02, 2010, 11:09:13 AM »
Does anyone have the number of the Kury. shifter  peg  we can mount on the shifter to make it easyer to downshift a Rattlebars kickshifter my stock peg is a little short. Thank You Scooter6
vanagon40
Greenwood, IN
« Reply #1 on: March 02, 2010, 11:38:00 AM »
Not sure if you mean 8021 (longhorn) and 8004 (standard).
http://www.cruisercustomizing.com/detail.cfm?model_ID=102&Category_ID=0&manufacturer_ID=16&product_ID=4136
« Reply #2 on: March 02, 2010, 11:42:58 AM »
Also:     http://bigbf.com/bigbf_shop/shift_peg/
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #3 on: March 03, 2010, 03:02:09 AM »
I tried that years ago, never had much luck with it's funtion, although it looked good. Mine was not a good fit, always loose. The set screw was tiny and could not be tightened properly. I wrapped my peg in small pipe strap, then fit this peg over it. That worked for a short while, then I gave it to someone who needed one on the board.
  Maybe others have tried it and had better luck?
SgtBunny
"Don't be a Lemming!" - MCC
Kingwood, WV
« Reply #4 on: March 03, 2010, 07:19:28 AM »
I did this mod and love it.  Looks awesome and has been rock solid.
Only problem I had initially was a touch of rust where I ground the old peg off which I fixed with a quick shot of clearcoat after touching it up with a piece of sand paper.
VRCC #29625
'98 Tourer
vanagon40
Greenwood, IN
« Reply #5 on: March 03, 2010, 11:09:15 AM »
Tundra,
I think you may be referring to the Kuryakyn 8851, which slips over the existing peg.
http://www.directlineparts.com/product.asp?pid=2847&str=2
I (and I believe the other posters) was referring to the Harley peg that requires grinding off the existing shift peg and drilling and tapping a new hole to mount the new peg (KUR-8021 or KUR-8004)
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #6 on: March 03, 2010, 03:53:05 PM »
Yup...you are correct. Please disregard my post. Appologize.  Embarrassed
vanagon40
Greenwood, IN
« Reply #7 on: March 03, 2010, 07:44:21 PM »
Tundra,
No reason to apologize and no reason to disregard your post.  I think the 8851 got lousy reviews, and you confirmed that it was not a good purchase.
You might want to try the other modification for the Kury peg.
[I'd post a picture but I'm on dial-up.]
