January 30, 2026, 12:29:18 PM *
Author Topic: Ordered GL1800 front rotors today. One question though.  (Read 2046 times)
Tropic traveler
Silver Springs, Florida
« on: March 17, 2010, 06:10:14 PM »
Spent $400 at HDL today, the lions share of that on 2 new Goldwing rotors to replace the VERY worn stockers on my '97. I'll hit 99,000 miles this weekend & it's also time for a new front Avon. So I thought while I have the front wheel off I'll slap on the new rotors. Already have new OE pads & new wheel bearings in my stash. I also ordered all new retaining bolts for the rotors just in case.
The question I have is, are the rotor bolts gonna be a PITA to get out considering the age & miles on my Valk? Also, I ordered Valkyrie retainer bolts not GW bolts, is that combo gonna work properly?
Any help or tricks from those of you that have been there & done that is appreciated! cooldude
'13 F6B red for Kim
« Reply #1 on: March 17, 2010, 06:39:54 PM »
My bolts came of easy on the rear wheel. its alot worse then my front. 50,000 miles tho.
quexpress
Montreal, Québec, Canada
« Reply #2 on: March 17, 2010, 06:42:25 PM »
If you have problems, heat them up a little with a propane torch to break the old thread lock.
Yes these are the required ones.
Same steps as installing OEM rotors. You'll be alright!  cooldude
I still have a full deck.
I just shuffle slower ...
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: March 17, 2010, 07:47:24 PM »
You might try breaking them loose while the tire is still on the bike and on the ground.
Marty
« Reply #4 on: March 17, 2010, 08:53:34 PM »
When I put the rotors on the front of MGM from across the pond, I also replaced the mounting bolts, so I just hit my old ones with the impact wrench.    NO problem.
I also added anti sieze to the mounting bolts.
