« on: March 20, 2010, 06:50:12 AM » |
I realize the manual pingel petcock I just installed has a smaller reserve than the stock petcock, I just filled up with 4.5 gallons with my tourer, and I hadn't reached reserve yet with the pingel. Was I close, I hope? I usually get gas around 150 miles on a tank. thanx if you know how much reserve it has. Hoser
« Reply #1 on: March 20, 2010, 06:56:13 AM » |
You should be close. I usually hit resv around 150ish, depending on riding style. I think my resv is around 20 miles or so. Pulling trailer, 2-up its 8 mile resv.  I normally get 32 mpg on my 98 Tourer.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #2 on: March 20, 2010, 07:24:37 AM » |
I found my reserve milage was cut in half-ish. I stop for fuel @ 150 miles on the clock, good rule of thumb for me. If I do hit reserve, I make sure I stop at the nearest fuel stop. Won't play games like I used to, too heavy for pushing
« Reply #3 on: March 20, 2010, 07:26:49 AM » |
Sounds about right that would be around a half gallon, I can live with that, just takes some planning ahead. Thanx, Fudgie. Thanx Tundra  hoser
X Ring
VRCC #27389, VRCCDS #204
« Reply #4 on: March 20, 2010, 09:30:05 PM » |
You should be close. I usually hit resv around 150ish, depending on riding style. I think my resv is around 20 miles or so. This is what I was told by other Pingel users when I bought mine. Marty
junior
« Reply #5 on: March 21, 2010, 02:37:05 AM » |
the one i just installed leaves me jist under a gallon of gas on reserve i have an I/S tandk on a 97 tourer, i have been getting about 200 miles before res with the oem petcock yesterday i got 189 miles before res
Red Diamond
« Reply #6 on: March 21, 2010, 06:19:16 AM » |
Don't want to hijack this thread, Junior, did you use your stock seat on your tourer when you installed the I/S tank? I would like to install an I/S tank on my 2k Tourer and was wandering about that. Also I seem to be getting less miles per gallon on the tourer, than on the 99 I/S. Hit reserve at about 143 miles.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #7 on: March 21, 2010, 07:22:42 AM » |
Stock seat worked perfectly when I added I'State tank to mine.
Red Diamond
« Reply #8 on: March 21, 2010, 07:37:27 AM » |
Thanks, didn't want to make a bunch of changes to get one on, have an extra I/S seat, but the back clip doesn't end up in the right place. Besides, I like the tourer seat better than the I/S seat.
junior
« Reply #9 on: March 21, 2010, 10:40:10 AM » |
Don't want to hijack this thread, Junior, did you use your stock seat on your tourer when you installed the I/S tank? I would like to install an I/S tank on my 2k Tourer and was wandering about that. Also I seem to be getting less miles per gallon on the tourer, than on the 99 I/S. Hit reserve at about 143 miles.  i have a corbin seat that came on the bike when i bought her, but i still had to trim the horn of the seat down to accept the I/S seat
rmrc51
Palmyra, Virginia
« Reply #10 on: March 21, 2010, 12:57:14 PM » |
I can tell ya that the Ultimate seat for a standard or a tourer will "Not", fit when an Interstate tank is installed. I was lucky because I had just bought my Ultimate seats around a month before I went to an IS tank. Des at Ultimate offered to do and exchange for me as long as my seat was in perfect shape, which it was. It all worked out perfectly. I love having the extra fuel capacity along with a real Gas Gauge (Moto Sen Gauges).  And,, I also have a Pingel non-vacuum installed.
« Last Edit: March 21, 2010, 12:58:54 PM by rmrc51 »
VRCC # 30041
« Reply #11 on: March 21, 2010, 01:32:47 PM » |
I can tell ya that the Ultimate seat for a standard or a tourer will "Not", fit when an Interstate tank is installed. I was lucky because I had just bought my Ultimate seats around a month before I went to an IS tank. Des at Ultimate offered to do and exchange for me as long as my seat was in perfect shape, which it was. It all worked out perfectly. I love having the extra fuel capacity along with a real Gas Gauge (Moto Sen Gauges).  And,, I also have a Pingel non-vacuum installed.  Can the motosen gauge be tapped into a standard tank?
« Reply #12 on: March 21, 2010, 01:47:00 PM » |
I can tell ya that the Ultimate seat for a standard or a tourer will "Not", fit when an Interstate tank is installed. I was lucky because I had just bought my Ultimate seats around a month before I went to an IS tank. Des at Ultimate offered to do and exchange for me as long as my seat was in perfect shape, which it was. It all worked out perfectly. I love having the extra fuel capacity along with a real Gas Gauge (Moto Sen Gauges).  And,, I also have a Pingel non-vacuum installed.  I had a fairly new Big Boy Ultimate when I got my I/S tank and wasn't about to spend more for a replacement. I put the seat on with the tank, but had to press down on the front a bit to get it locked in. I then used some soap to mark on the tank where the nose contacted it, then applied some black automotive deco tape in that area. Kept the seat from rubbing the paint and you couldn't see it. As for fit, after the first couple times of riding, the seat locked right into place. That nose is quite flexible and will push up a bit when pressed against an I/S tank. It will wrinkle the leather a bit but not enough to bother, and it's less expensive than buying a replacement. I used it like that for about three years until I replaced it with a seat made for the I/S.
« Reply #13 on: March 21, 2010, 01:49:41 PM » |
"Can the motosen gauge be tapped into a standard tank?" ++++++++++++++++++++++++++++++++++++++++++++++++++++++++
The gauge won't do you any good if you don't have a sending unit in the tank like the I/S tank has.
« Reply #14 on: March 21, 2010, 01:53:51 PM » |
Ah, got ya.
rmrc51
Palmyra, Virginia
« Reply #15 on: March 22, 2010, 06:48:46 AM » |
What John said. Only the IS tank has the access plate/area to accept the sending unit for the fuel gauge.
VRCC # 30041
rmrc51
Palmyra, Virginia
« Reply #16 on: March 22, 2010, 06:51:17 AM » |
I can tell ya that the Ultimate seat for a standard or a tourer will "Not", fit when an Interstate tank is installed. I was lucky because I had just bought my Ultimate seats around a month before I went to an IS tank. Des at Ultimate offered to do and exchange for me as long as my seat was in perfect shape, which it was. It all worked out perfectly. I love having the extra fuel capacity along with a real Gas Gauge (Moto Sen Gauges).  And,, I also have a Pingel non-vacuum installed.  I had a fairly new Big Boy Ultimate when I got my I/S tank and wasn't about to spend more for a replacement. I put the seat on with the tank, but had to press down on the front a bit to get it locked in. I then used some soap to mark on the tank where the nose contacted it, then applied some black automotive deco tape in that area. Kept the seat from rubbing the paint and you couldn't see it. As for fit, after the first couple times of riding, the seat locked right into place. That nose is quite flexible and will push up a bit when pressed against an I/S tank. It will wrinkle the leather a bit but not enough to bother, and it's less expensive than buying a replacement. I used it like that for about three years until I replaced it with a seat made for the I/S. That's interesting and great information for others who might have Ultimate seats on a standard or tourer and are considering installing an IS tank!
VRCC # 30041
