February 08, 2026, 08:31:51 AM
Hydrolocked the number 3 cylinder......
Topic: Hydrolocked the number 3 cylinder...... (Read 2666 times)
2tonevalk
Whazzup????
March 11, 2009, 01:20:39 PM »
Ok, well I found the book on my 98 Valk. The tubes that were rotted were the drain hoses from the bowls.
I turned the idle screw on the number 4 cylinder as shown in the manual and now my bike idles.
I tried to start it when I made the adjustments and it would not turn over. Pulled all the plugs. The number 3 was locked.
Now to the question. What is everyone doing to repair as the dealers do not sell a petcock rebuild kit. Does this mean the petcock diaphram is leaking? Or is this usually a once in a while thing?
All help is greatly appreciated. I can pick up a petcock at hdlparts for just over a hundred dollars. Anyone using the Pingle petcock? Is this an easy switchover?
Re: Hydrolocked the number 3 cylinder......
March 11, 2009, 01:36:11 PM »
04 SCREEN SET 16952-MZ0-003 $11.26
05 COVER SET,rooster 16953-MBZ-B51 $26.17
There's an easy vacuum test in the Shoptalk
article that will help you make sure you did
the rebuild properly before you put your
bike back together...
Dag
Country Rep. Norway
March 11, 2009, 03:16:56 PM »
Here is a good description by CHOLLA:
http://www.valkyrienorway.com/partspetcock.html
John U.
Southern Delaware
March 11, 2009, 03:48:08 PM »
There are quite a few using the Pingle. There are vacume and non-vacume models. I haven't changed over yet, but a hydrolock scares the bejesus out of me. If you hydrolocked with no damage to the starter or worse, you are lucky.
One other thing you could consider is installing a fuel filter. A hydrolock means that the fuel flow was not stoped by the petcock and a float valve was not closing completely. Grit getting past the screen can cause this.
Shotgun
Canadian Lakes, Michigan
March 12, 2009, 02:45:29 AM »
I had it happen to me. I had to put a new rear case on the engine, along with a bunch of gears, etc. Made me sick, I put in a fuel filter and and electronic shut off. It's been two years. So far, so good.
greatcoat
fuel shut off
March 10, 2014, 11:48:09 AM »
Riders,
I am looking to install an electronic fuel shut off to help prevent another hydrolock..Will you please recommend a shut off unit that will do the job
Thank You
Poor Ol Harry
Baytown,TX. East of Houston
Reply #6 on:
March 10, 2014, 12:53:45 PM »
Being a hydro lock survivor with minor damage, I installed a manuel Pingle & shut it off well before killing engine.
Re: fuel shut off
Reply #7 on:
March 10, 2014, 12:55:38 PM »
Quote from: greatcoat on March 10, 2014, 11:48:09 AM
Riders,
Thank You
Some fellas are using the Dan Marc valve. Many of us use the manual Pingle valve.
