February 01, 2026, 01:11:18 PM *
Author Topic: Throttle Cables  (Read 3055 times)
Red Diamond
Beaumont, Texas
« on: March 23, 2010, 05:13:52 PM »
I am planning to change the throttle cables on the 2K Tourer because the metal on the  connectors are rusted. When I looked at the cables on my 99 I/S, I noticed they where routed differently. (See Pics). Has anyone installed I/S throttle cables on a Standard or Tourer? I looked at both carefully and didn't notice any difference in the routing. It seems that would work, unless someone knows of a particular difference, perhaps electrical or something. TIA
2K Top Picture, 99 I/S Bottom
« Reply #1 on: March 23, 2010, 05:30:22 PM »
Well I'll be.  ??? Never noticed the diff before. My Tourer looks like top pic.
D.Tater
Jacksonville, FL
« Reply #2 on: March 23, 2010, 06:33:18 PM »
The connector chrome is junk. Mine are rusty and I have seen others that are rusty also.
Is the norm to replace with OEM/ aftermarket?
Does someone make SS ones?
David
'97 Standard
Red Diamond
Beaumont, Texas
« Reply #3 on: March 23, 2010, 06:42:36 PM »
Yes I consider mine junk also, yes there are stainless steel braided ones out there, I'm too cheap to buy them, don't like the way they connect and will probably stick to OEM's, would like to keep it as original as possible.
X Ring
VRCC #27389, VRCCDS #204
« Reply #4 on: March 25, 2010, 10:18:13 PM »
Iirc, the cables are the same.  The switchbox is different.  The I/S switchbox has the cables enter on the bottom where the Standard/Tourer enter from the front.  I couldn't adjust the brake lever where I wanted it since the cables were in the way on my Tourer so I installed the I/S box.
Marty
ETA:  I shouldn't post when I'm tired.
« Last Edit: March 27, 2010, 08:56:34 AM by X Ring » Logged
Colin
My old job
Orba, Spain
« Reply #5 on: March 25, 2010, 11:20:17 PM »
Iirc, the cables are the same.  The switchbox is different.  The I/S switchbox has the cables enter on the bottom where the Standard/Tourer enter from the front.  I couldn't adjust the clutch lever where I wanted it since the cables were in the way on my Tourer so I installed the I/S box.
Marty
I didn't know you were a 'southpaw'  Roll Eyes  Grin It must have been late when you were typing this Marty.  2funny
Colin
VRCC Espana
My Bumble Bee re-build
AussieValk
Gold Coast, Australia
« Reply #6 on: March 26, 2010, 04:21:06 AM »
I've had the braided ones on my IS for a few years now, don't remember which brand, maybe Motion Pro (?) and they're as good as the day they went on. They're slightly longer than stock but fit fine. Worth the money I reckon.
Red Diamond
Beaumont, Texas
« Reply #7 on: March 26, 2010, 04:33:58 PM »
I was thinking my thread was forgotten, thanks X-RING, I'm in the process of ordering a switch box for an interstate from HDL. They are running about 58 bucks for an I/S and 68 bucks for a Tourer, go figure that one. With the cables running under the brake lever, vs on top of it, gives that part a cleaner look.
Farther
Quimper Peninsula, WA
« Reply #8 on: March 26, 2010, 05:00:45 PM »
The IS switch box looks like it might give a few more inches for the cables to accomodate additional rise in the handlebars or risers.  I may have to look into that for my poor shoulder.
~Farther
Red Diamond
Beaumont, Texas
« Reply #9 on: April 23, 2010, 06:09:54 PM »
2K Top Picture Tourer, Bottom 99 I/S
[/quote]Little over a month or so ago I purchased a 2k unkept Tourer and wanted to change the throttle cables to route like the ones on my 99 I/S. I finally found a handle bar switch housing with cables, wiring, and a super vista cruise all in tack from Pinwall. Everything was good to go except on Bl/W wire. After I studied the electrical schematic, I decided to remove the switches from the Tourer and install them in the I/S housing, which was the item I really needed to re-route the cables. My picture of the I/S will show how the cables are now routed on the Tourer, as I didn't take a new picture. Hope this helps for anyone wanting to perform the mod.
Farther
« Reply #10 on: November 14, 2010, 03:57:41 PM »
Would someone provide the parts number for the IS throttle cable housing please or provde me with the IS model designation such as GL1500??.  I know my standard is GL1500CD but I don't know what the IS model designation is.
~Farther
Pete
« Reply #11 on: November 14, 2010, 04:13:49 PM »
If the rust is surface rust without any significant pitting:
then use 4 ought steel wool and a good grade auto cleaner wax and polish.
The rust will be removed leaving a shiny waxed surface that will look good for some time.
Then steel wool and wax again.
Same process will remove surface rust on chrome with out scratching.
Bone
« Reply #12 on: November 15, 2010, 03:44:10 AM »
CF for the Interstate model
Is this what your looking for from HDL ?
05 SWITCH, STARTER STOP
35013-MBY-010  (replaces 35013-MBY-000)  001 $76.76 $58.26
« Last Edit: November 15, 2010, 03:57:06 AM by Bone » Logged
« Reply #13 on: November 15, 2010, 09:16:35 AM »
The reason the Interstate keeps the chrome parts of the throttle cables much better is the benefit of being behind the fairing, out of the wind-stream, rain-stream, dirt-stream.  Take your pick!
Farther
« Reply #14 on: November 16, 2010, 12:55:39 PM »
Thanks for the information.  That is what I was looking for.
~Farther
Farther
« Reply #15 on: November 30, 2010, 03:57:34 PM »
I decided to remove the switches from the Tourer and install them in the I/S housing.
  I'm wanting to do this because I have a bad switch and I like the routing of the IS switch box.  So what I need is the guts from the Standard switch box, housing from the IS switchbox and cables from the IS?  I don't think the elbow fitting on the Standard cable will fit the IS switch box.  Please tell me if you know different.
~Farther
