September 10, 2025, 12:10:21 AM *
Author Topic: i need a carb float hinge pin  (Read 889 times)
blackcat
Nicholas Vore VRCC # 30301
Mounds, Arkansas
« on: March 26, 2010, 05:35:40 PM »
while i had the carburetors off the bike and apart for cleaning and re-jetting,   i lost one of the float hinge pins. tickedoff
only way i have found to get a new one is to order the entire float assembly, which is $40 or more.
does anyone have a extra pin.
until i get another pin i used a matching size drill bit cut to length, it works but i don't want to use it for long in case it corrodes
nick
______________________
03 Standard -Fast Black
00 Interstate - Red/Black
97 Tourstate - Yellow/Ivory
2010 Goldwing - Pearl Yellow
alph
Eau Claire, WI.
« Reply #1 on: March 26, 2010, 07:24:53 PM »
Nick,
Why would it corrode?  It’s not subjected to air and moisture.  Should be fine I think.  You can buy stainless steel craft wire at the craft store, or use brass, copper from electrical wire, there’s a lot of other options if you’re worried of corrotion.
Dennis Klinefelt
« Reply #2 on: March 27, 2010, 06:46:50 AM »
I can send you one...shoot me an e mail....easy_48843@yahoo.com   rock on dennis
