January 30, 2026, 03:30:02 PM *
Author Topic: Hi Beam Relay  (Read 2397 times)
Stude
« on: March 30, 2010, 06:56:05 AM »
Anyone know of an aftermarket 12 volt "Neutral Open" Relay
that will work on a Valkyrie for the hi beam switch
 tickedoff
« Reply #1 on: March 30, 2010, 07:33:11 AM »
 tickedoff
Most all relays have a dual use in that they can be used to disconnect or make a connection.
There are at least two families of relays:  Momentary and latching.
Valkyries don't have headlight relays as stock.
You must be contemplating adding additional lighting controlled with a relay. That's the correct way to do it.
If you want to use the stock toggle on the handlebars and use it in conjunction with the high beams only you should probably investigate whether the wiring can carry the additional load of a relay in the high beam circuit.
A possible solution could be move the high beam wire to the relay also and then stock high beam wire could be dedicated to the relay singularly.
In any case, you will need a new supply wire directed to the relay for your power needs.
Stude
« Reply #2 on: March 30, 2010, 09:30:27 AM »
 I hate to disagree but I replaced the rocker switch for the hi beam and it still did not work.
found that when I tried to jumper it at the switch I could hear a faint click from under the seat.
And it was coming from a relay, pulled the relay next to it and switched it for the bad one and
the hi beam worked. Took it out and put the bad one back in, and the light did not work. Tapped
on the bad relay with a screwdriver and the hi beam came on. Switched off then on and tapped on
it and the hi beam came on.... what ya think, is it a relay or were the 60's a little to good to me.
If you ask me the answer is both  crazy2
Stude
« Reply #3 on: March 30, 2010, 11:18:09 AM »
Stude: I thought I heard that the I/S's have a relay in the lighting circuits. I haven't seen the I/S wiring but Radio Shack has both Normally open and normally closed relays. Pull the bad one and take it there. You might get lucky.
Rio Wil
« Reply #4 on: March 30, 2010, 03:23:33 PM »
Try your local auto salvage yard for a source of high quality 10-15-20-30 and even 40 amp rated relays. Pin configuration is usually printed on the relay and various mounting methods available.
« Reply #5 on: March 30, 2010, 03:56:55 PM »
Stude
I guess you're disagreement is about no headlight relay in the Valkyrie.
Here's a link for the wiring schematic on the Valkyrie. Done up by someone right here on the forum.
There's no relay in the headlight (high beam/low beam) system in the schematic.
3W-lonerider
Shippensburg Pa
« Reply #6 on: March 30, 2010, 05:49:15 PM »
as far as i know..theres no relays in the circut on the standard and tourer models. but there is a high and low relay on the i/s models.. best thing i can tell ya stude..take it to an auto parts or radio shack..they may be able to match it up..NAPA sells alot of different relays with pin configerations.
John U.
Southern Delaware
« Reply #7 on: March 30, 2010, 06:16:13 PM »
3W-Lonerider is correct, the I/S has relays for the headlights. Go to the link below, about 4/5s of the way down there is info on relays and how to wire them to take the load off the starter switch. Also there is a schematic to beef up the wiring to handle higher wattage bulbs.
http://www.rattlebars.com/valkfaq/circuits.html
Valkpilot
What does the data say?
Corinth, Texas
« Reply #8 on: March 30, 2010, 06:42:07 PM »
Two headlight relays on the Interstate:
http://www.rattlebars.com/valkfaq/schematics/rpage04i.html
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Stude
« Reply #9 on: March 30, 2010, 07:34:49 PM »
Thanks everyone I found a relay @ Auto Zone 30 amp for $5.00 ...
I over looked  Jeff K's  post in shop talk and
JimC
SE Wisconsin
« Reply #10 on: March 30, 2010, 08:03:59 PM »
Thanks John,
I was looking to do that mod and I could not find the schematic.
And thanks Chet for taking the time to make it and putting it where we could all use it.
Jim
Jim Callaghan    SE Wisconsin
